how to setup a new cog?
if i wanted this program to run on two different cogs with two different frequencies on two different pins, how would i do it?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
txpin = 16
freq1 = 500
freq2 = 1000
delta = 50000
txfreq = 92_500_000.0
freqb = round(txfreq * 4_294_967_296.0 / (16.0 * 80_000_000.0))
PUB main | numclks1, numclks2
dira := 1 << txpin
numclks1 := clkfreq / (2 * freq1)
numclks2 := clkfreq / (2 * freq2)
ctrb[30..26] := %00010
ctrb[25..23] := 7
ctrb[5..0] := 16
repeat
' Generate the first frequency for one-half second
repeat freq1 >> 1
frqb := freqb + delta
waitcnt(numclks1 + cnt)
frqb := freqb - delta
' Generate the second frequency for one-half second
repeat freq2 >> 1
waitcnt(numclks2 + cnt)
CON
txpin = 16
freq1 = 500
freq2 = 1000
delta = 50000
dira := 1 << txpin
ctrb[25..23] := 7
ctrb[5..0] := 16
repeat
repeat freq1 >> 1
repeat freq2 >> 1
The Propeller Education Kit Labs tutorial has several sections on using multiple cogs and on using the counters. You might have a look at it.
Spin does not do floating-point calculations inline like that, [edit]except in constant expressions, which is what you have[/edit]. You have to make method calls to one of the floating-point objects for each operation.
Finally,
I was under the impression that the compiler would convert floating point calculations, just wont work at run time. He has it placed in the CON block so I see no reason it would not work.
pub set_freq(ctrx, freq, pin) '' Sets ctrx to freq on pin (NCO/SE mode) '' -- freq in hz freq := clkfreq / freq ' convert freq for NCO mode freq := ($8000_0000 / freq) << 1 case ctrx "a", "A": ctra := ((%00100) << 26) | pin ' configure ctra for NCO on pin frqa := freq ' set frequency dira[pin] := 1 ' make pin an output "b", "B": ctrb := ((%00100) << 26) | pin frqb := freq dira[pin] := 1And, Bits, I's so glad you're feeling well enough to correct me!
Looks like both frequencies are the same and going to the same pin, or is that just because it's a template
Incidentally if I were to have more frequencies that meant more cogs
I've figured out to start a new cog with newcog,main@ stack command and long stack variable but how can I pass variables such as frequency and pin number with different values to different cogs? And don't you have to specify which cog?
set_freq("A", 5, 0) set_freq("B", 20, 1)Easy as Pi.
Since the counters run on their own they will stay at the desired frequency until you change them. Which causes me to think that I should have a way of stopping a counter. If the freq is 0 or lower, this update should do it.
pub set_freq(ctrx, freq, pin) '' Sets ctrx to freq on pin (NCO/SE mode) '' -- freq in hz '' -- use freq of 0 to stop counter that is running if (freq > 0) freq := clkfreq / freq ' convert freq for NCO mode freq := ($8000_0000 / freq) << 1 case ctrx "a", "A": ctra := ((%00100) << 26) | pin ' configure ctra for NCO on pin frqa := freq ' set frequency dira[pin] := 1 ' make pin an output "b", "B": ctrb := ((%00100) << 26) | pin frqb := freq dira[pin] := 1 else case ctrx "a", "A": ctra := 0 ' disable counter outa[pin] := 0 ' clear pin/driver dira[pin] := 0 "b", "B": ctrb := 0 outa[pin] := 0 dira[pin] := 0if i want 2 fm frequencies each on two cogs so in total 4 frequencies how would i do that?
would i just do
newcog,Pub???@stack
set_freq("A", 48, 0) set_freq("B", 100, 1)
then just repeat this for each cog?
how do i specify which cog to run which frequencies on?
bit lost sorry, real newbie!
pri freqout_2x(p1, f1, p2, f2, killpntr) ' launch with cognew() '' Run one or both counters in NCO mode '' -- designed to run in background cog if (p1 => 0) ' output on this pin? ctra := ((%00100) << 26) | p1 ' set counter for NCO on this pin (p1) frqa := ($8000_0000 / (clkfreq / f1)) << 1 ' set frqx for frequency (f1) dira[p1] := 1 ' set pin to output mode if (p2 => 0) ctrb := ((%00100) << 26) | p2 frqb := ($8000_0000 / (clkfreq / f2)) << 1 dira[p2] := 1 long[killpntr] := false ' let cog run after setup repeat { let counter(s) run } until(long[killpntr]) cogstop(cogid) ' kill this cogHere's how I called it with my test:
In the test pins P0 and P15 output 5Hz for five seconds, then I kill the cog by setting stopblinks to true. Note that for this I use the pin first, then the frequency (will probably change my set_freq() to this as well).
The worst thing you can do (in my opinion) is try to get ahead of yourself. It would probably do you a lot of good to read and work through the Propeller Education Kit manual; you can find it under the Help menu in the Propeller Tool.
