Is this right? Schematic for FTDI to BS2P40
W9GFO
This is my first time messing with an FTDI chip. I have tried to figure out the proper wiring using a combination of the QuickStart schematic, USB BOE schematic and the Bs2P40 schematic. Unfortunately, none of them quite exactly match what I need so I am unsure if I have done it correctly.
Comments are appreciated.
The safest thing to do would be to compare yours with the BOE USB schematic:
Also, the BOE schematic shows test left open. The data sheet says to ground it and the QuickStart shows it that way. Why is it not grounded on the BOE?
The serial interface to all of the BASIC Stamps should be the same, else how could they plug into the BOE and be expected to work? If you're interfacing directly to an SX48, though, things will definitely be different.
I think you know, the BS2P40 is an SX48 chip. I can find no schematic or data sheet for the BS2P40 flavored SX48 - other than the drawing that is on the BS2P40 module.
I was hoping someone knowledgeable could double check my schematic for peace of mind.
I need to find out what is the minimum required to go from the FTDI directly to the chip - not a module.
Just to be extra clear, I want to have the FTDI and the BS2P40 (chip, not module) right next to each other on the same PCB.
http://www.robotworkshop.com/robotworkshop/projects/parallax/BS2p40OEMschematic.pdf
Robert
