Wanting to get started with an LCD Touch Screen — Parallax Forums
groggorygroggory Posts: 205
edited 2012-08-18 08:06 in Propeller 1
Honestly, I'm a bit overwhelmed by all the touch screen threads going on here. I've read every one I can get my hands on and I don't know what path I should start on.
Here's what I want:
~3-4" LCD that can be seen in daylight
Single Touch, resistive (I'll be putting a protective plastic film over it)
An interface board that is open source so that I can later integrate it onto my PCB design (for space saving)
Code to run the thing, lol
Low cost parts as much as possible
I'm planning on using this as a control interface for a program I'm building. So basically, it'll throw some statistics to the screen and will have a few buttons on the screen. Pretty simple stuff.
I've thought about using a multi-line LCD screen and some buttons for control...but having a touch screen would be so slick and if the price is where I hope it is...roughly the same cost once you factor in all the other buttons and stuff I need to support them on a nice case.
Thank you for the help. I'm usually a self-solver, but I'm just overwhelmed here.
  • average joeaverage joe Posts: 795
    edited 2012-08-17 14:40
    Hi groggory, Sounds interesting. The TouchBurger Dr. Acula and I have been working on might be right up your alley. These are fast, flexible boards at a reasonable cost IMO. Without displays, they're about $50 to build. The thread is a bit long so the specs are as follows:
    p8x32A-d40 @ 80mhz
    2- 512k Sram with fast address bus
    ports for 2 standard 40-pin LCDs *tested with 3.2" SSD1289 and 2.4" ILI9325, should also work with SSD1963
    Stereo audio output.
    2-ch 8 bit ADC.
    Expansion boards with tv, vga, keyboard, rs323, RTC, and more
    about 30 pins free *pins are accessed in groups*
    lots of code, with more on the way. Able to draw BMPs from SD card, many fonts, all open source.
    A bit more about your application would help. What external devices are you interfacing with?
  • RaymanRayman Posts: 16,033
    edited 2012-08-17 14:55
    There are low-cost 3.5" and 4.3" touchscreens at Rayslogic.com.
    There were meant for units like GPS, so they work well outside...
    If you want capacitive touch, we've just figured out how to do that with the Newhaven 4.3" touchscreens too...
  • groggorygroggory Posts: 205
    edited 2012-08-17 15:01
    Rayman wrote: »
    I've been doing a lot of reading on your site as of late.
    So for $5 for a used LCD + $19.99 for a breakout board I can get started on this path? Sounds really cool. I'll send you an email today. Is the code on your page the most current code for that display?
    http://www.rayslogic.com/Propeller/Products/PSB/PSB_Display.htm#Breakout_Boards
    As far as the capacitive touch, is that touch or multi-touch?
    What model Newhaven screen are you referring to? The NHD-4.3-480272MF-ATXI#-CTP-1
    edited 2012-08-17 15:04
    p8x32A-d40 @ 80mhz
    2-ch 8 bit ADC.
    My main thing I need is 3 RS232 ports, a RTC, an SD card, and a couple I/O. That part isn't a big deal. I have a custom PCB that I've developed that deals with that. Still a work in progress, but I have that part under control.
    I just need to decide on what display to go with and make sure the display with make sense if this product gets built in quantity for resale.
  • HShankoHShanko Posts: 402
    edited 2012-08-17 15:07
    Don't know if he is still selling them, but I got a 3.5" touchscreen that worked great for my application from Rayman...
    Use it to display the outpot of a D/A. Has several 'buttons' on-screen for specific touch points. Two cursors to measure time between events. Long battery life, has SC card socket.
    edited 2012-08-17 15:10
    HShanko wrote: »
    Wow, that looks exciting.
    I'm stoked to move from the world of serial terminals and buttons everywhere to a nice, easy to customize, touch LCD
    edited 2012-08-17 15:22
    I think that is the right Newhaven model number. It's 5-point multi-touch with pinch gesture recognition.
    Right now, it's a little cumbersome to connect (you'd need jumper wires), but I do sell a little $3 connector breakout that makes it easier...
    The resitive one is easier, just plug it in...
    edited 2012-08-17 15:29
    Rayman wrote: »
    Email sent. Let's get this party rolling
    edited 2012-08-17 18:08
    Actually that is the bit that has had averagejoe and me stumped for months *grin*.
    Put in all those extras and there are less pins. Less pins = slower updates to the display. So we initially got it working with less pins (8 bit mode) but it was too slow. With full color touchscreens, a display is 240x320x2 bytes which is a lot more than the propeller memory. So for fast updates - moving sprites around, icons, refreshing screens etc you need to be able to dump data from ram to the display very fast. The somewhat strange design averagejoe and I have, with all those extra chips, is because we started with the core of the design a fast ram to display interface, and then added the propeller later.
    For more ports and I/O we have gone for a second board with another propeller on it.
    Having said all that, if the display is not being changed much you can move things from the SD card to the display. (ballpark, about 2 secs to draw a display from an SD card, and about 0.03 seconds from external ram). I'm using these displays http://www.ebay.com.au/itm/2-4-TFT-LCD-Module-Display-Touch-Panel-PCB-adapter-SD-Card-Cage-320-240-New-/270973667234?pt=LH_DefaultDomain_0&hash=item3f174a07a2 $13.95 with free shipping and averagejoe is using one a bit larger
    edited 2012-08-17 21:33
    If you NEED an RTC, then the expansion board will be quite handy. The 3 RS232 should be easy, I'm not sure if Doc is @ ready to print expansions, maybe we could make a couple tweaks. If your 232 ports handle hardware handshaking, it could probably be done with the TouchBurger and a few gates *74hc32 (ORs) for idle high* The couple I/O is the one with the ? What will the I/Os be doing? Is it "mission critical" to have the I/Os connected at all times? If they're just watching buttons, a MCP32008 I2C bus expander will be PERFECT. *the expansion has 2 of these* Really, what are the RS232s doing? A bit more info, we can get this pinned down!
    edited 2012-08-18 04:16
    groggory,
    Here are some tips for deciding between the 3.5 and 4.3" products from Rayslogic.com:
    Most people prefer the 4.3" displays because it has higher resolution and larger size.
    Also, the driver board is simpler than the 3.5" version.
    Rayslogic.com has "like new" and "used" versions at low cost.
    You can also connect the same LCD to the new Rayslogic.com DVI graphics shield with the 4.3" plugin adapter,
    in case you one day need 24-bit color graphics.
    But, the 3.5" display also has some advantages...
    It is smaller and so uses less power.
    The screen resolution is smaller so it uses less Propeller resources.
    The small physical size may be needed for small devices.
    The new PTP2 driver board increases color depth from 6 to 8 bits and so can show more colors than the 4.3" version.
    Rayslogic.com sells "new" displays at a very low cost.
    BTW: Both of these boards have the same touchscreen chip that also has
    analog inputs you can use for measuring things like battery voltage. It
    also can tell you the temperature. The PTP2 board also has a few
    expanded digital I/O pins on the same connector as these analog ADC
    inputs.
    edited 2012-08-18 07:09
    FYI to anyone reading.
    It seems to me that Rayman's setups are a simpler setup that can easily 'glue' onto any project for relatively low cost.
    The Touchburger is more of a full, integrated solution...but also keeps the ability to add onto it. The Touchburger has significantly better performance at the expense of more IO, more supporting chips, and more COGs necessary to get it running.
    My preference: I bought both. The touch burger from Joe and the PTP2 (gadget gangster usb) w/ 3.5" display from Ray.
    Hats off to all the developers of this stuff! Everyone is awesome and doing great things for the community and this platform
    Thanks again for purchasing a Touchburger kit. There has been a significant amount of effort in designing a robust platform with plenty of room for expansion. Using the SRAM does increase overhead a bit, bit it's worth the performance boost IMO. Plus it solves the problem of not having enough RAM on the propeller chip itself. Although we're currently using PEAK of 4 cogs *Main program, ramdriver, SPI and SD*, the usage could be brought down to 2 I think. Current drivers use about half of the hubRam, but that includes quite a few features not every program will use.
    Ray has quite a few interesting goodies, great for gluing into projects like as you said. I must order a DVI Graphics shield some day :D
