10 conductor ribbon cables for Propeller Proto USB board?
David Betz
I've finally gotten around to finding time to play with one of the Propeller Proto USB boards that I bought ages ago and notice that the connections to the Propeller pins are in groups of 8 with VSS and VDD lines for each group. It seems to me that it would be nice to be able to solder 10 pin male headers to the proto board and use ribbon cables to connect them to off-board parts. Does anyone make 10 conductor female-to-female cables that would be appropriate for this?
http://www.digikey.com/product-detail/en/A3BBB-2006M/A3BBB-2006M-ND/1982449
http://www.digikey.com/product-detail/en/1700%2F20%20100SF/MC20F-100-ND/145537
http://www.digikey.com/product-detail/en/AWP20-7240-T-R/HKC20H-ND/924343
It's not very hard to add the IDC connectors to 10 wire ribon cable. I haven't been able to use their "breadboard friendly" connectors without having them break.
At least compared to the platforms, Quickstart, etc,
So for the Proto board I make little plug-in modules with angle pin headers and perf board.
that worked out really well.
https://www.adafruit.com/products/266
pity they don't have them in blocks of 10, joined single-inline, but I guess this is an ultra flexible approach
