Build an automated Pill Machine.. your expertise.. is there any parts we have miss
We purchased the basic stamp discovery kit RECENTLY, with LCD Termnial Appmod and DS1302 chip, & DS1302 time keeping chip.
We are working on building an automated pill machine. Basically, it works like an alarm clock, when the desired timing is reached, the LED would light up and at the same time turns the motor. From your expertise, would there be any PARTS that we would be missing from the list?
I am really sorry for the trouble but because we are new to these materials and please do tell us if you know any.
We look forward to hear from you soon..
Regards
LBC
Regards
LBC
If the thing fails in odd ways and ends up over dosing or under dosing it's user you are going to be feeling very bad.
A while back a young friend of mine with diabetes ended up in hospital with seriously wrong blood sugar levels. In the hospital they discovered that her new blood glucose meter was way out of calibration.
So, in addition to timing, and dispensing, maybe you want to sense if payload is present or not, and try to determine (a likelihood) if the item was delivered and obtained in the proper time frame.
Also, consider what happens if each part of the system doesn't work (power loss, mechanical failure, software failure, operator failure, not enough pills, too many pills, etc).
Good luck on this, it sounds like a fun project.
