Propeller BOE pin assignments?
Carol Hazlett
On the Propeller BOE are I/O pins 14 & 15 the same pins as the servo pins 14 & 15? I am asking because I was going to use both but could find no way to address them seperately in the program code. It seems that they can not be used at the same time as each other. Thanks ahead.
When you say you were going to use them both, do you mean you were going to use the ones down the side to connect something and also use the ones at the servo headers to connect something?
If that's the case, you can't. Both sets of headers connect to the same pin on the chip.
"All roads lead to Rome" as it were
