Propeller DNA (PPUSB2) config files.
Attached below are the propeller-load config files for the new Propeller Platform USB compatible board, now called "Propeller DNA". Please replace "pp-usb-2.cfg" in the repository with these two files.
Thanks!
-edit--
(obsolete files removed)
Thanks!
-edit--
http://code.google.com/p/propgcc/issues/detail?id=51
Some problems:
Board Type: DNA
Memory Model: XMM-SPLIT
This works
Board Type: DNA:SQI
This fails. These are just two quick examples.
In terms of a Memory Model selection what do you do with DNA:HI, and DNA:SQIHI? With regards to the U12 socket, I think somebody plugged in some SRAM, what would be the Memory Model for that? I am basing my observations from the use of the C3 board. So, do we need some sort of flexible Memory Model selection process? I think we are going from SimpleIDE to ComplexIDE.
Ray
A simple matrix would probably be useful.
