Accessing string elements, casting?
In the following code, I've created a string using a long the string( ) call, and I've created a byte array to form the string "spin".
Why on the pst.str(foo[1]) does it not print p? If I include the @ operator to make it @foo[1], I get pin, not just the p. How would I pull only the p from foo?
Do I need to do some casting trickery on it? Is that what the byte[ ] syntax I've seen used on others' code? Casting? If not, please explain what that means, I'm having a hard time finding it. (or at least tell me the name of it so I can look it up.)
CON _clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ pst : "Parallax Serial Terminal"
VAR byte foo[10]
long bar[10]
PUB main
pst.Start(115200)
foo[0] := "s"
foo[1] := "p"
foo[2] := "i"
foo[3] := "n"
foo[4] := 0
bar := string("fun")
pst.str(foo[1])
pst.newline
pst.str(bar)
If you have a closer look at the used objects you'll find that the str method is usually based on the single character output method, e.g.
PUB [COLOR="blue"]str[/COLOR](addr) repeat strsize(addr) [COLOR="orange"]out[/COLOR](byte[addr++])How about the byte[ ] or word[ ] syntax I see used from time to time? What's that called/doing?
