Does anyone know if there is any C# or VB code written to use the HB-25 motor controller directly from a com port instead of having to use a stamp, or is it stamp specific only?
Sounds like a straight forward question. If you mean can you hook up an HB-25 to a com connection... probably not. The HB25 uses a single pulse width for control... so unless you can trick your com port into outputting a pulse with controlled pulse width, you are out of luck. I'm not saying it isn't possible... but it kind of sounds that way. At the same time it isn't stamp specific. You can use anything to output the pulse... Prop/arduino/etc.
Rich
