Stepper Motor Vs. Servo Motor
NWCCTV
So I am almost to the point of actually doing some hardware work for my overall project. It has been a long time coming!!!! I will be implementing a robotic arm in my project and unlike many homemade ones that I have seen, this thing needs to be quite strong. It needs to (at a minimum) be able to grasp and lift a full 12-16 Oz. can of liquid. I am thinking that a Stepper motor would be my best choice, since when there is power to them but no commands being sent, they are pretty much frozen in place. Looking for the experts advice on this one.
At 90 degree the fulcrum, @, feels (1 lbs.)(1 ft)sin(90) of twisting force or 1ft-lbs of torque.
Keep this in mind when designing your robotic arm.
Hey, I'm just the Enabler...!
BTW, didja see they're down to $3.01 now?
http://www.ebay.com/itm/5V-Stepper-Motor-28BYJ-48-With-Drive-Test-Module-Board-ULN2003-5-Line-4-Phase-/320933811659?pt=LH_DefaultDomain_0&hash=item4ab92555cb
If bargains were drugs, I'd be a pusher!
A closed-loop (PID) servo will not only hold position but your controller will always know the true position of the axes. Furthermore, by limiting the motor command output, you limit the motor torque which can provide compliance when clamping-up on the load. Torque-limit is also useful for "teaching" the motion path.
Mickster
FYI: Industrial robots such as ABB, Fanuc, Kawasaki, Motoman, Kuka, et-al, are exclusively closed-loop servo controlled. However, I do understand that we are on a hobbyist theme here.
Mickster
