Bending a tube without the walls collapsing or pinching....
 Beau Schwabe
Beau Schwabe
                    Anyone have an idea how to bend a 1/4' diameter brass or copper tube into a "U' shape without collapsing the side walls and pinching the tube?  .. The tube is only 6 inches long to begin with.
BTW) I have tried taping the ends and packing it with salt prior to bending it and that did not work... perhaps I need to pack the salt in it tighter.
-thanks
-thanks
Like these http://www.ridgid.com/Tools/Spring-Tube-Benders
Home Depot sells some online.
OTOH, if the tubing tube is flared on both ends, you'll have to use a tubing tube bender:
Jim
The spring should work although I have seen ice used to help keep the diameter constant during a bend
Thats how they do musical instrument brass slides.
Jim
http://www.youtube.com/watch?v=kh7RrlazaRc
For brass tubing, use a brake line bender found at the auto parts store. However the key to bending brass tubing without kinking it is to anneal it first with propane or mapp gas. After you heat it up and let cool, you should be able to bend the U Shape without kinks.
Bruce
EDIT: This would probably also work for copper
I thought perhaps I should add more information.
While bending, ensure that the bending shoe is always firmly against the tube to prevent slippage, and additionally, place the tubing on a flat level surface and ensure that the excess tube is always flat against the work surface and that the bender is in firm contact with the tube.
Here's a reference;
http://steamshed.com/annealing%20process.html
