Instructing the bot to move around dynamically
Hi,
I am using Boe Bot in my college for robotics practicals, and am enjoying working with it.
I came across an idea where, I mount a sensor (like Kinect) on top of the Boe Bot and compute the status of the bot on a laptop (which is interfaced with the Kinect through USB through OpenKinect drivers). (Cakewalk till here)
Then, I want to direct my bot to move accordingly, after computing the instructions to be carried out next, again, through USB. (Would probably happen using higher level languages like Octave) The obvious obstacle in doing this is that the Boe Bot controller only reads from memory that has been already written on in the read mode, before the bot has actually begun working.
Is there a way around this, or is instructing the bot to dynamically move around through USB completely impossible?
EDIT: Thanks!
EDIT: Thanks!
http://www.devx.com/dotnet/Article/33216
One challenge is controlling the servos and doing serial I/O. It can be done, but a servo pal makes life easier.
As I said, the Bluetooth interfacing is no big deal, it could be USB as well.
I haven't had problems with USB or RS-232 ports, but I was just pre-programming the bot. If there's a concern about speed when controlling the bot dynamically as I mentioned, I am ready to switch to RS-232 too.
Thanks for the reply. Want to mark this thread 'almost solved', but that's not an option
Unfortunately my work got insane around May and I program for a living. As a result, I have not wanted to fiddle off hours.
http://forums.parallax.com/showthread.php?139578-Python-and-BoeBotControlForMsrsCtp2
@execat: Welcome to the forum and where are your manners? You used the "N" word! "Nevermind" is a rude way to reply to Martin_H, who took the time to reply three times in an effort to help you. Please refrain in future posts.
