floattoformat
Can't get floatforformat to compile. The other Float String routines compile
I get an "expected a subroutine name" on the last line above no matter how I type it. The priors FloattoString and others compile. I checked the module and the routine is there.
Jerry
f1:=float32.FFloat(micros) ' micros is now floating
f2:=float32.FFloat(1000000)
fps:=float32.FDiv(f1,f2)
pst.str(fs.floattostring(fps))
pst.Chars(pst#NL, 2)
f2:=float32.FFloat(1)
fps:=float32.FDiv(f2,fps)
pst.str(fs.FloatToFormat(100.0,8,2))
Jerry
I'm pretty sure you can get by without that method.
If you're just using basic arithmatic you don't really need floating point numbers. You just multiple by 1000 or some other number to retain precision. You can then use a method "DecPoint" (a forum search should turn it up) to display the number with a decimal point in the desired location.
I'm pretty sure I have a copy of the float to string object that uses floattoformat, I'll find it and post it here in a bit.
Here's the method using PST method calls:
PUB DecPoint(value, denominator) if value < 0 Pst.Char("-") -value if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0") Pst.Char(".") repeat while denominator > 1 denominator /= 10 if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0")If you had a variable "x" which held the value "123456" and you wanted this value displayed as "123.456", you call the above method with;
PUB FloatToFormat(single, width, dp) : stringptr | n, w2 ''Convert floating-point number to formatted string '' '' entry: '' Single = floating-point number '' width = width of field '' dp = number of decimal points '' '' exit: '' StringPtr = pointer to resultant z-string '' '' asterisks are displayed for format errors '' leading blank fill is used ' get string pointer stringptr := p := @float_string ' width must be 1 to 9, dp must be 0 to width-1 w2 := width := width #> 1 <# 9 dp := dp #> 0 <# (width - 2) if dp > 0 w2-- if single & $8000_0000 or positive_chr w2-- ' get positive scaled integer value n := F.FRound(F.FMul(single & $7FFF_FFFF , F.FFloat(teni[dp]))) if n => teni[w2] ' if format error, display asterisks repeat while width if --width == dp if decimal_chr byte[p++] := decimal_chr else byte[p++] := "." else byte[p++] := "*" byte[p]~ else ' store formatted number p += width byte[p]~ repeat width byte[--p] := n // 10 + "0" n /= 10 if --dp == 0 if decimal_chr byte[--p] := decimal_chr else byte[--p] := "." if n == 0 and dp < 0 quit ' store sign if single & $80000000 byte[--p] := "-" elseif positive_chr byte[--p] := positive_chr ' leading blank fill repeat while p <> stringptr byte[--p] := " "I get '****.**' for output so something is wrong.
I tried using integer math and couldn't get it to work.
I have a delta time number in clock ticks like 43385201. This gets divided by 80_000_000 to get seconds. 1 divided by seconds turns into feet per second and displayed to two decimal positions. I need to do all this within the rate of fire for the automatic weapon we are timing with the high end of 1,800 rounds per minute or 3 per second.
Thanks for the help,
Jerry
