Using th Button command — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2012-08-06 14:29 in BASIC Stamp
Questin, Would a Button command be the appropriate approach to the following code to invoke a "reset" after each of the Servo commands? If so, how would I code it and if not, what should I use.
IF x = 1 THEN
  pulseleft = 850: pulseright = 650: pulsecount = 24:
  DO UNTIL  (counter = pulsecount)
  PULSOUT 13, pulseleft
  PULSOUT 12, pulseright
  counter = counter+1000
  LOOP
ELSEIF x = 2 THEN
  pulseleft = 650: pulseright = 850: pulsecount = 24:
  counter=counter+1000
  LOOP
ELSEIF x = 3 THEN
  pulseleft = 850: pulseright = 750: pulsecount = 24:
  PAUSE 20
  LOOP
ELSEIF x = 4 THEN
  pulseleft = 750: pulseright = 650: pulsecount = 24:
  DO UNTIL  x = 6
  PAUSE 20
  LOOP
ENDIF
counter = 0
LOOP
    edited 2012-07-31 14:08
    Not sure exactly what you want the pushbuttons to do, but you're missing a couple of PAUSE 20's in your code.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-07-31 14:23
    Yes, I am aware of this. What I need to do is invoke a reset within the software after each of the commands that turn the servos for the specified time.
  • Mike GMike G Posts: 2,702
    edited 2012-07-31 15:40
    What do you want to reset?
    This will loop forever as counter will never equal pulsecount.
     IF x = 1 THEN
      LOOP
    Maybe this is what you are trying to do?
    *** NOT TESTED ***
    ' {$STAMP BS2p}
    ' {$PBASIC 2.5}
    LOOPS         CON 24
    RESET         CON 750
    x             VAR Byte
    pulseleft     VAR Word
    pulseright    VAR Word
    counter       VAR Word
    Init:
      counter = 0
      x = 0
    Main:
      x = (x + 1)//5
      GOSUB PrepareCommand
      GOSUB SendCommand
    GOTO Main
    PrepareCommand:
      IF x = 0 THEN
        pulseleft = RESET: pulseright = RESET
      ELSEIF x = 1 THEN
      ELSEIF x = 2 THEN
      ELSEIF x = 3 THEN
      ELSEIF x = 4 THEN
      ENDIF
    RETURN
    SendCommand:
      FOR counter = 0 TO LOOPS
        PAUSE 20
      NEXT
    RETURN
    edited 2012-08-01 11:44
    Echoing the question, what do you mean by "invoke a "reset""?
    The BUTTON command is usually overkill, unless you need the auto-repeat feature. It is easier to read the button-switch with a simple IN command. Are you using an original BS2?
    edited 2012-08-01 13:29
    I am using a newer BS2. I need to reset the BS2 in the software after each Servo rotation. I know this loops and would need it to rerun after the reset. This needs to be applicaple for each of the Servo commands.
    IF x = 1 THEN
      LOOP
    edited 2012-08-02 09:04
    Sorry, I still don't understand. Maybe it would help if you could insert a comment or two in your example code to illustrate what you want to happen where. For example, is this what you want
    [FONT=courier new]IF x = 1 THEN
       pulseleft = 850 : pulseright = 650 : pulsecount = 24
         counter = counter+1000  ' <---- WHY R U adding 1000, to match with pulsecount=24?!
        ' if user presses the STOPbutton while this is
        ' running, then stop immediately, go back to
        ' the main menu and wait for another command.
      [/FONT][FONT=courier new][/FONT][FONT=courier new]LOOP[/FONT]
    edited 2012-08-05 17:49
    OK. I will try to clarify. I know I need to pull the "Loop" command out and place at the end of the code. I do not want the user to have to press anything. I want the sofware to send a "Reset" after each statement is executed. The code is executed via an external C# pushbutton. Each "Pushbotton" represents the numbers 1-4. I hope this clarifies the situation.
    IF x = 1 THEN  pulseleft = 850: pulseright = 650: pulsecount = 24:  DO UNTIL  (counter = pulsecount)  PULSOUT 13, pulseleft  PULSOUT 12, pulseright  counter = counter+1000
     LOOP
    "[U][B]Reset Here"[/B][/U]
    ELSEIF x = 2 THEN
     pulseleft = 650: pulseright = 850: pulsecount = 24:  DO UNTIL  (counter = pulsecount)  PULSOUT 13, pulseleft  PULSOUT 12, pulseright  counter=counter+
    1000  LOOP
    [U][B]"Reset Here"[/B][/U]
    ELSEIF x = 3 THEN
    pulseleft = 850: pulseright = 750: pulsecount = 24:  DO UNTIL  (counter = pulsecount)  PULSOUT 13, pulseleft  PULSOUT 12, pulseright  counter=counter+1000  PAUSE 20
     LOOP
    ELSEIF x = 4
    THEN  pulseleft = 750: pulseright = 650: pulsecount = 24:  DO UNTIL  x = 6  PULSOUT 13, pulseleft  PULSOUT 12, pulseright  counter=counter+1000  PAUSE 20  LOOPENDIFcounter = 0LOOP[U][B]""Reset Here"[/B][/U]
    [IMG]http://forums.parallax.com/images/misc/progress.gif[/IMG][URL="http://forums.parallax.com/editpost.php?p=1114653&do=editpost"][IMG]http://forums.parallax.com/clear.gif[/IMG] Edit Post[/URL]
    edited 2012-08-05 18:55
    NWCCTV, what are you trying to reset? The STAMP, set the servos to neutral, initialize variables...???
    Are you trying to detect a reset command on the serial line issued by software running on a PC? If so, you must poll the serial line within your looping construct in PBASIC. The Stamp does not have a serial port buffer and the Stamp can only do one thing at a time. So, the only time the Stamp can detect a reset command on the serial line is when the Stamp is looking for a command on the serial line. The PC software should resend the reset command until the Stamp acknowledges receiving the reset command. After the acknowledgment, the stamp will reset something...
    edited 2012-08-05 19:44
    Back in post 6 I stated I need to reset the BS2 (STAMP) in the software. If this is not doable then I will try another route. I do not want to mess with the C# code. It works fine.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-08-05 23:40
    All a reset does is make the Stamp start back at the beginning of the program. Just add a label at the very beginning of the program and use a GOTO, or use one of the Stamp's pins to pull the the reset pin low and force it that way.
    edited 2012-08-06 12:30
    NWCCTV,
    Connect a resistor (10k) to the Stamp's reset line, and the other end of the resistor to +5V (make sure it's really 5V).
    Dedicate a Stamp pin to use for the operation/purpose.
    Connect the dedicated pin to the Stamp reset pin (maybe through a 220 resistor).
    In the Stamp code, set the dedicated pin to output, default "high".
    Then, when a Stamp reset is desired, programatically pull the dedicated pin low, which will in turn reset the Stamp.
    Lemme know?
    ***edit post...guess I should have read RDL2004's post a bit more carefully!
    edited 2012-08-06 14:08
    Well, your post was much more detailed :)
    I should also point out that just using a label with GOTO commands isn't going to clear anything already in memory (variables and such), so you would need to deal with that.
    So I should create a sub routine to clear the memory and and then use the Goto "main" to start over, correct?
