1,000,000,000,000,000 watt LASER
Berkeley Laser Fires Pulses Hundreds of Times More Powerful Than All the World's Electric Plants Combined
http://news.yahoo.com/berkeley-laser-fires-pulses-hundreds-times-more-powerful-200000374.html
EXCERPT:
Imagine a device capable of delivering more power than all of the world s electric plants. But this is not a prop for the next James Bond movie. A new laser at Lawrence Berkeley National Laboratory was put through its paces July 20, delivering pulses with a petawatt of power once per second. A petawatt is 1015 watts, or 1,000,000,000,000,000 watts about 400 times as much as the combined instantaneous output of all the world s electric plants.
How is that even possible? Well, the pulses at the Berkeley Lab Laser Accelerator (BELLA) are both exceedingly powerful and exceedingly short. Each petawatt burst lasts just 40 femtoseconds, or 0.00000000000004 second. Since it fires just one brief pulse per second, the laser s average power is only about 40 watts the same as an incandescent bulb in a reading lamp.
EXCERPT:
Now let's see that LASER last a few Sec . .....
Lawson
N2 Lasers are like this in a way .
Peter
In all mediums the velocity of the photons move slower than the Speed of Light in free space. This speed in some mediums is slower as the power density increases. Since the leading edge of the pulse is slowed the trailing light kind of piles up on the front, causing more slowing and so on.
Apparently the pulse is shortened many thousands of times which greatly increases the peak power.
Cool huh!!
Duane J
Fusion and weapons research was the primary usage back in the 1980's. But it makes sense that it might work as a linear accelerator too.
Usually these pulses are in the infrared. But interstellar communication via lasers is definitely on the list of technologies SETI researchers consider viable.
