fopen bug
I think I've found a bug in the fopen code when using the FileDriver.
You can't open a file for writing without truncating it or forcing append mode
I need to open an existing file for read and write. open("foo","r+")
In lib/drivers/FileDrivers.c, the File_fopen code only looks at the first character of the mode (mode[0]).
As a result, only DFS_READ is set on DFS_OpenFile and writes are ignored.
If mode[0] == 'r' and mode[1] =='+' then both DFS_READ and DFS_WRITE need to be set.
Below is the code I used to test. Changing "r+" to "w+' shows the failure.
#define printf __simple_printf
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <cog.h>
#include <propeller.h>
#include <unistd.h>
uint8_t dbuf1[128];
uint8_t dbuf2[128];
extern _Driver _SimpleSerialDriver;
extern _Driver _FileDriver;
/* This is a list of all drivers we can use in the
* program. The default _InitIO function opens stdin,
* stdout, and stderr based on the first driver in
* the list (the serial driver, for us)
_Driver *_driverlist[] = {
&_SimpleSerialDriver,
&_FileDriver,
NULL
FILE *dp;
* Test the fopen/fread/fwrite/fseek/fclose routines
int main(void)
int i;
int diskoffset;
for(i=0; i<128; i++) {
dbuf1[i] = 0xaa;
printf("Starting fopentest\n");
if ((dp = fopen("foo","r+")) == 0) {
printf("fopen failure\n");
exit(-1);
printf("fopen ok\n");
diskoffset = 0;
fseek(dp, diskoffset, SEEK_SET);
printf("write seek: %d\n", diskoffset);
printf("write data: %x\n", dbuf1[0]);
fwrite(dbuf1, 1, 128, dp);
fflush(dp);
printf("read seek: %d\n", diskoffset);
fread(dbuf2, 1, 128, dp);
printf("read data: %x\n", dbuf2[0]);
I also discovered that c3files no longer works in LMM mode because there wasn't enough memory for the heap and the stack. The libraries are using up a bit more space than they used to. I disabled mkdir and rmdir in c3files when in the LMM mode to free up some space.
Thanks.
