Interface for Serial LCD Module KTM-S1201
I never like to re-invent the wheel so has anyone used one of these displays with a Prop?
Looks stright forward but I'm sure it's not.
Rick Murray
Rick Murray
Here is a link to a .pdf that gives helpful hints and some more documents references on the LCD module. Ignore the link to necel.com - it doesn't work!
There should be an object in the OBEX (click the button at the top of the forum) that can be adapted.
Hope this helps
EDIT: You could try adapting the TLC5940 (LED Painter driver) or maybe the Serial Com (CS, SDA, CLK) object.
