Slip Rings
ajward
Hey All...
Has anyone experience transferring power and/or signals through a slip ring? Something like a continuously rotating sensor array.
Just toying with some ideas here. (Like I don't have enough unfinished projects going on! :-| )
Thanks for any wisdom!
Amanda
Amanda
http://www.adafruit.com/blog/2012/03/12/slip-ring-video/
http://www.ebay.com/sch/Electrical-Test-Equipment-/92074/i.html?_nkw=slip+ring
If you need something really heavy duty 150Amps or higher I have s source for those but they will need to be cleaned up before using them.
Robert
Look at the German made "Neutrik" electric guitar type.
The ones that have gold plated brass machined barrel, ring, and tips.
I have tested these to about 30 amps and work well with only slight temperature rise.
Duane J
Ended up getting one of these:
http://www.ebay.com/itm/260991849118?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_4654wt_1398
It'll cost less than just the parts for a home made device.
Amanda
6x2x220= 2.64 kilowatts through it' while it's rotating at 250 RPM (4 revs/second)
So you can make a military or commercial-grade rotating full-power radar antenna installation around this part. Not bad for 8 bucks! I'm jealous I didn't find it, Robert!
I'd imagine servo signals would be fine but what about really fast(~1MHz) SPI signals?
I'll probably get a few myself. An ultrasound sensor on a CR servo would be pretty cool.
I would think that the "Through Hole Slip Ring" would be the most useful since you have a motor shaft, etc placed inside the slip ring.
I found some on ebay - $95 though...
