12V 5Ah SLA Rechargable Battery for PEK
Hello.
Was wondering if there would be ANY reason to worry about using my 12V sealed lead acid rechargable battery, or even my huge car battery, to supply input to the LM2940(5.0) DC regulator on my PEK board. The data sheet specifies that the battery is well within range for supply input, and a .47 uF electrolytic capacitor is installed across the supply input for my wall-wort.
In theory, everything looks OK, but don't want to risk damaging my expensive components (drawing less than 1A total).
Is the LM2940 going to be a reliable "Doorman", protecting everything downstream indefinately?
I'm thinking that I might be missing at least something somewhere.
Thanks for your assistance.
The data sheet after all states that the voltage regulator was designed for vehicles, so the whole story would make perfect sense.
Thanks for the response:)
Remember that that battery on full charge would be 13.8 V to 14.4 V depending on the charger scheme. The advice of putting in a fuse (very near the battery terminals) is very apt, the surge capability of these batteries is swift and brutal.
And NEVER expect any rechargeable battery to be limited to the 'nominal operating voltage'. Charging generally requires a higher voltage to rearrange the chemistry to a full charge.
And be sure to follow the capacitor specifications for the LM2940 as other voltage regulators have very different requirements.
If it is used in an actual automobile you may have to resolve specific problems as the starter solenoid, the horn, and switching headlight levels put significant transients into the supply.
