Propeller + Max3443 = 921kbps?
I'm trying to communicate with a device over rs485 that specifies it needs 921,600 baud with 8N1 formatting. To this end I've got a MAX3443 driver chip, but none of the obex objects I could locate seem to support this rate. I know spin won't go that fast, and since I'm a novice at assembly so I was hoping to find something in the OBEX that would do the heavy lifting for me.
Anyone have an easier method? It seems I'm on the path to rolling my own solution based on some of the other forum posts I've seen regarding high speed serial comms. If it helps, the data will be sent intermittently in chunks of about 10 to 20 bytes at a time so only minimal buffering is needed.
Any input is appreciated.
Greg
Greg
I suspect if there's a serial driver out there using PASM it will easily be adaptable to that baud rate (by someone knowledgable in PASM).
I found Peter's code for doing serial tx and rx, I'll use that as the basis for my object. I only need be either sending or receiving at any one time, but have the capability to both (half duplex). Looks like I'm going to learn PASM after all.
Greg
