Problem connecting Eddie
I am new to robotics. I have installed MRDS4 with Kinect 1.5. I have assembled Eddie robot as per the instructions given in parallax website.
When I type KinectUI in MRDS command prompt (used 32bit as well as 64 bit), I get the following error
When I type Eddie, I get the following error
Can you pl. help me to sort this problem?
I have also tried running Eddie manifest from Manifest Editor. I get error when I tried to run Eddie.manifest and EddieObstacleAvoid.manifest. But when I tried to run EddieObstacleAvoid.user.manifest, it is working fine showing dashboard and Kinect images.
Pl. help me out.
Regards
Sumit
Pl. help me out.
Regards
Sumit
Did you build the samples before you attempted to run them? There's a service in Start -> Microsoft Robotics Developer Studio 4 -> Build All Samples. I have run into this issue myself and running that fixed it.
Let us know if there is still an issue.
Cheers,
Jessica
