Anyone else seeing broken "code" window text?
potatohead
I've attached two screen shots, one from the Mozilla browser window, and another of notepad after a cut 'n paste from the browser "code" window?
This just started happening recently.
I ran into this a while back. I THINK I found the solution somewhere in the parallax forums but haven't bothered searching for it. Wherever it is, it needs a bump. If I recall correctly it had something to do with the font rendering options in FF.
Here you go:
http://forums.parallax.com/showthread.php?135271-All-text-now-lumped-together-after-forum-upgrade
http://forums.parallax.com/showthread.php?135290-Spin-graphics-no-longer-rendering-in-code-blocks
Other search results were returned as well if the solution is not there.
