CompactFlash I/O — Parallax Forums
CompactFlash I/O
CircuitsoftCircuitsoft Posts: 1,166
edited 2012-07-21 12:43 in Propeller 1
I have a CF WiFi card (AmbiCom WL1100C-CF, Intersil Prism-based) that I would like to try to use with the Propeller. I've found the Intersil Prism Driver Programmer's Guide but am unsure how many lines need to be connected and how they need to be driven to control it.
Clearly, it can be driven by a micro, but many details of that are missing, and I'm not sure where else to look.
Any ideas?
    edited 2012-07-20 09:27
    You need to look at the Wikipedia description of the CompactFlash card and its derivatives. Note that this uses a 50-pin interface which normally transfers 16 bits at a time. I don't recommend using this with the Propeller or any other micro because of the number of I/O pins required. You can always multiplex the I/O pins by adding some external latches and buffers, but that makes the interface more complicated.
    Note that the "micro" you refer to is a micro-processor, not a micro-controller like the Propeller. The difference in this case is that the Rabbit microprocessor has a full external memory and I/O bus with at least 20 address bits (1MB) and 8 data bits.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-07-20 09:30
    From what I understand, you can do 8-bit transfers if you strobe the pins right. I've seen references to that in other docs about using this chip with micros, but the doc I found didn't have complete details on that.
    edited 2012-07-20 09:43
    I suspect the CF card defaults to 8-bit transfers and you can probably get away with an 8-bit address bus. That's still a lot of I/O pins. Start with the Wikipedia article and follow some of the links to find the ATA and CF bus hardware descriptions.
  • groggorygroggory Posts: 205
    edited 2012-07-20 10:39
    Also, what draws you to using compactflash? SD is so much simpler when you're dealing with micros, and is cheap to boot
    edited 2012-07-20 11:05
    groggory wrote: »
  • pedwardpedward Posts: 1,642
    edited 2012-07-20 15:05
    Seems that SDIO was stillborn after the days of the Handspring devices that supported it.
    edited 2012-07-21 08:24
    Many moons ago I looked into CF I/O. I seem to recall determining that you need a minimum of 14 I/O lines to do CF transfers. CF is basically the same as parallel ATA hard drive interface and you can plug a CF card into an ATA hard drive socket with a passive adapter and it looks like a hard drive to the host.
    edited 2012-07-21 10:31
    I've read that you can do 8-bit I/O on a CF card, but ATA/IDE requires full 16-bit transfers.
  • rallyordierallyordie Posts: 4
    I am designing a system now using CF and a PIC24. SD/MMC cards just don't cut it in wide-temp, high vibration applications. Google 'ELM FatFs' for an excellent tutorial on talking to CF and a FAT file system. Chan provides a reference design based on an AVR that is easily adapted to other processors.
    I looked at using the Propeller (I've used it on other projects), but plenty of I/O and the parallel master port makes it simple to implement a fast CF interface for the PIC24 without extra hardware.
