Frequency Generation Tests — Parallax Forums
g3cwig3cwi Posts: 262
edited 2012-07-17 07:05 in Propeller 1
Various people have suggested that the jitter performance of the counters will be better when they are generating frequencies that are exact mutiples of the clock frequency. As I want to generate 10.140MHz I did some tests:
The plots below show 10.140MHz being generated from a 5MHz clock crystal (span 30MHz and 1MHz).
The next set show 10.140MHz being generated with a 10.140MHz clock crystal.
Perhaps you might notice the difference?
Next I will investigate jitter at small offsets.
Cheers
Richard
  • g3cwig3cwi Posts: 262
    edited 2012-07-14 10:01
    1 KHz offset - OMG
    5Hz offset - so bad it even sounded dreadful on a receiver.
    Conclusions : using a crystal close to or at your wanted frequency is a dreadful idea unless you want an unmodulated signal (CW).
    Cheers
    Richard
    1024 x 549 - 67K
    1024 x 549 - 53K
    edited 2012-07-14 10:34
    Yup, small offsets are ugleee! I ran into the same problem with my PLL retrofit for the MFJ Cub 40m transceiver. Its VFO output includes 5 MHz (mixed with 12 MHz). I had to replace the Prop's 5 MHz crystal with one at 4.9152 MHz to get out of that awful jitter zone.
    edited 2012-07-14 10:37
    Hi Phil
    A better use of my 10.140MHz crystals will be to build a filter as you suggested previously. I have three so that's the next job! I will revert to a 5MHz clock for the prop.
    Cheers
    Richard
    PS my Prop 8mW WSPR signal spanned the Atlantic last night on 20m. Code by KO7M.
    edited 2012-07-16 09:31
    The addition of a 2KHz wide 10.140MHz filter and a seven element low pass filter has resulted in a nice clean output. Interestingly the WSPR "drift" figure has also improved. Now running at 20dBm on 30m.
    Cheers
    Richard
    edited 2012-07-16 10:33
    You could probably pour white noise through a filter like that and get clean output! :)
    edited 2012-07-16 20:13
    g3cwi: Richard, perhaps you might like to show us your propeller circuit you are using? I am interested to see how much is being done by the prop.
