Frequency Generation Tests
Various people have suggested that the jitter performance of the counters will be better when they are generating frequencies that are exact mutiples of the clock frequency. As I want to generate 10.140MHz I did some tests:
The plots below show 10.140MHz being generated from a 5MHz clock crystal (span 30MHz and 1MHz).
The next set show 10.140MHz being generated with a 10.140MHz clock crystal.
Perhaps you might notice the difference?
Next I will investigate jitter at small offsets.
Cheers
Richard
Cheers
Richard
5Hz offset - so bad it even sounded dreadful on a receiver.
Conclusions : using a crystal close to or at your wanted frequency is a dreadful idea unless you want an unmodulated signal (CW).
Cheers
Richard
A better use of my 10.140MHz crystals will be to build a filter as you suggested previously. I have three so that's the next job! I will revert to a 5MHz clock for the prop.
Cheers
Richard
PS my Prop 8mW WSPR signal spanned the Atlantic last night on 20m. Code by KO7M.
Cheers
Richard
WSPR CCT.pdf
