signed 32bit booth's multiplication (fastest in average)
This multiplication is not the fastest I have made. Some are quicker but not for every operation. This is probably the best in average you could do for 32bit signed multiplication. This one loop only 16 times at maximum (if you don't make overflow). I hope you will enjoy this: entry 'init result value mov R,#0 'make x the smallest 'optimization to ensure maximal 16 loops if no overflow abs x1,x abs y1,y CMP x1,y1 wc,wz if_nc mov y1,y if_nc mov y,x if_nc mov x,y1 test x,#1 wz if_nz sub R,y shl y,#1 loop test x,#1 wc test x,#2 wz if_nz_and_nc sub R,y 'if 10 sub if_z_and_c add R,y 'if 01 add shl y,#1 wz if_nz sar x,#1 wz if_nz cmp x,TRUE wz if_nz jmp #loop ret x LONG -99999 'ARG1 y LONG -2 'ARG2 R LONG 0 'RESULT x1 LONG 0 y1 LONG 0 TRUE LONG -1 here is a shorter one but not very optimised (negative number do 32 loops) : DAT org entry mov R,#0 test x,#1 wz if_nz sub R,y shl y,#1 loop test x,#1 wc test x,#2 wz if_nz_and_nc sub R,y if_z_and_c add R,y shl y,#1 wz if_nz shr x,#1 wz if_nz jmp #loop ret x LONG 12 'ARG1 y LONG 12 'ARG2 R LONG 0 'RESULT For information I have no propeller, I made this for a friend with a simulator. Here is the C version : #include int main(int argc, char** argv) { int multiplicand = atoi(argv[1]); int multiplier = atoi(argv[2]); unsigned int A=multiplicand; unsigned int P=0; int Q=multiplier; if (multiplicand < multiplier) { // swap P,Q could be made with xor unsigned int temp = Q; Q = A; A = temp; } if (Q&1) P-=A; A=1; A
DAT
org
entry
'init result value
mov R,#0
abs x1,x
abs y1,y
CMP x1,y1 wc,wz
if_nc mov y1,y
if_nc mov y,x
if_nc mov x,y1
test x,#1 wz
if_nz sub R,y
shl y,#1
loop test x,#1 wc
test x,#2 wz
shl y,#1 wz
if_nz sar x,#1 wz
if_nz cmp x,TRUE wz
if_nz jmp #loop
ret
x LONG -99999 'ARG1
y LONG -2 'ARG2
R LONG 0 'RESULT
x1 LONG 0
y1 LONG 0
TRUE LONG -1
not optimised but short :
DAT
org
entry
mov R,#0
test x,#1 wz
if_nz sub R,y
shl y,#1
loop test x,#1 wc
test x,#2 wz
if_z_and_c add R,y
shl y,#1 wz
if_nz shr x,#1 wz
if_nz jmp #loop
ret
x LONG 12 'ARG1
y LONG 12 'ARG2
R LONG 0 'RESULT
C version :
#include <stdio.h>
unsigned int P=0;
int Q=multiplier;
Q = A;
A = temp;
if (Q&1)
P-=A;
A<<=1;
while (Q!=-1 && Q) {
switch(Q&3) {
case(2):
P-=A;
break;
case(1):
P+=A;
break;
Q>>=1;
A<<=1;
printf("%i\n", multiplicand*multiplier);
printf("%i\n", (int)P);
If you could implement it better in pasm, please let me now.
denis
unsigned int P=0;
int Q=multiplier;
if (abs(multiplicand) < abs(multiplier))
Q = A;
A = temp;
if (Q&1)
P-=A;
A<<=1;
switch(Q&3) {
case(2):
P-=A;
break;
case(1):
P+=A;
break;
Q>>=1;
A<<=1;
I am pleased!
Perry
