Code Help Needed
NWCCTV
How would I modify the following code to use local Comm Port 7 instead of Bluetooth:
' -----[ Title ]--------------------------------------------------------------
' File: BoeBotControlForMsrs.bs2
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ DATA ]---------------------------------------------------------------
ResetOnOff DATA 0 ' On/off toggle w/ Reset button
RequestConnect DATA $FF, 0, 1, 0, 0
ConnectionGranted DATA $FF, 0, 2, 0, 0
RequestCommand DATA $FF, 0, 3, 0, 0
ServoSpeeds DATA $FF, 0, 4, 0, 0
' -----[ Variables ]----------------------------------------------------------
tLeft VAR Word ' Servo control pulse durations
tRight VAR Word
temp VAR Word ' Temp variable
' Buffer array not declared as buffer VAR Word(5) for SERIN functionality.
' It can still be accessed as buffer(0), buffer(1), etc. However,
' buffer0, buffer1, etc. should be used in SERIN commands with variations
' of WAIT.
buffer0 VAR Byte ' Buffer - Start char = $ff
buffer1 VAR Byte ' Message Index value
buffer2 VAR Byte ' Command
buffer3 VAR Byte ' Argument 1 (return data 1)
buffer4 VAR Byte ' Argument 2 (return data 2)
buffer VAR buffer0 ' For standard array indexing
duration VAR Byte ' 50ths of ms duration
frequency VAR Byte ' 50ths of frequency
pointer VAR Byte ' EEPROM pointer
msgIndex VAR Byte ' EEPROM message index
routine VAR Nib ' Routine selector
counter VAR Nib
index VAR Nib
flagWhiskers VAR Bit ' Act on Whisker values
flagDigSens VAR Bit ' Send back digital sensors 1/0s
' with every reply
flagIr VAR Bit '
tempBit VAR Bit
' -----[ Initialization ]-----------------------------------------------------
' This code makes it possible to toggle the Boe-Bot on/off by pressing and
' releasing the Board of Education's Reset button.
Program_Start:
' For on/off toggle with Reset
' READ ResetOnOff, temp
' temp = temp + 1
' WRITE ResetOnOff, temp
' IF temp.BIT0 = 0 THEN
' FREQOUT 4, 1000, 2000 - Indicate inactive
' END
' ENDIF
HIGH 15
FREQOUT 4, 75, 4500
LOW 15
Reset:
DEBUG CLS
'Wait for the eb500 radio to be ready.
PAUSE 1000
'Wait for the EB500 Bluetooth connection to be established.
DO UNTIL IN5 = 1: LOOP
GOSUB Ram_Clear
Request_Connect:
pointer = RequestConnect
GOSUB Get_Packet
SEROUT 1, 84, [STR buffer \5]
Confirm_Connect:
pointer = ConnectionGranted
GOSUB Get_Packet
Wait_For_Confirm:
SEROUT 1, 84, [255, 0, 1, 0, 0]
SERIN 0, 84, 20, Wait_For_Confirm, [WAITSTR buffer \ 2,
buffer2, buffer3,
buffer4]
Request_Packet:
msgIndex = msgIndex + 1
pointer = RequestCommand
GOSUB Get_Packet
' -----[ Main Routine ]-------------------------------------------------------
DO
Resume: ' If Message not rcvd, try again
IF IN5 = 0 THEN Reset ' EB500 disconnected?
PULSOUT 13, tLeft ' Servo control pulses
PULSOUT 12, tRight
SERIN 0, 84, 5, Resume, ' Get next command
[WAITSTR buffer \ 2, buffer2,
buffer3, buffer4]
PULSOUT 13, tLeft ' Servo control pulses again
PULSOUT 12, tRight
IF buffer2 = 192 THEN ' Handle restart req from PC
msgIndex = 0
GOTO Request_Connect
ENDIF
LOOKDOWN buffer2,[32, 33,
64, 65,
96, 97, 98,
128, 129, 130,
160, 161, 162], routine
ON routine GOSUB Set_Servo_Speed, Maneuver,
Get_Ir, Get_Whiskers,
Speaker_Tone, Set_Pins, Delay,
Enable_Digital_Sensors, Enable_Ir, Enable_Whiskers,
Disable_Digital_Sensors, Disable_Ir, Disable_Whiskers
' Load digital sensor values into buffer byte 3 for return message.
IF flagDigSens = 1 THEN GOSUB Digital_Sensors
' Increment message index for reply. Next message from PC has to use
' reply's buf[1].
buffer1 = msgIndex
LOOP
' -----[ Subroutine Digital_Sensors ]-----------------------------------------
' This subroutine is used by the main routine to return digital sensor values
' with each reply.
Digital_Sensors:
buffer3 = 0
GOSUB Get_Ir
GOSUB Get_Whiskers
IF ((buffer3.BIT2 = 0 OR buffer3.BIT3 = 0) AND (flagWhiskers = 1)) THEN
tLeft = tLeft MAX 750
tRight = tRight MIN 750
ENDIF
RETURN
' -----[ Subroutine Set_Servo_Speed ]-----------------------------------------
' Range of 0 to 200 with 100 = stopped maps to 650 to 850 with 750 stopped.
Set_Servo_Speed:
tLeft = buffer3 + 650 ' Decode servo speed.
tRight = buffer4 + 650
RETURN
' -----[ Subroutine Speaker_Tone ]--------------------------------------------
Speaker_Tone:
duration = buffer3 ' Decode speaker tone
frequency = buffer4
FREQOUT 4, duration * 50, frequency * 50 ' Transmit tone
RETURN ' Go to resume routine
' -----[ Subroutine Get_Ir ]--------------------------------------------------
' IR object detection for buf[3] bits 1 (left) and 0 (right).
Get_Ir:
' IF flagIr THEN
FREQOUT 9, 1, 38500 ' IR headlight
tempBit = IN10 ' IR receiver
buffer3.BIT1 = tempBit ' Left IR reply bit
FREQOUT 3, 1, 38500
tempBit = IN2
buffer3.BIT0 = tempBit
' ENDIF
RETURN
' -----[ Subroutine Get_Packet ]----------------------------------------------
' Loads packet into buffer for transmitting. Used by initialization.
Get_Packet:
FOR index = 0 TO 4
READ pointer + index, buffer(index)
NEXT
buffer(1) = msgIndex
RETURN
' -----[ Subroutine Display_Command ]-----------------------------------------
' For debugging.
Display_Command:
' FOR index = 0 TO 4
' DEBUG DEC buffer(index), CR
' NEXT
RETURN
' -----[ Subroutine - Check_Whiskers ]----------------------------------------
' Stores left and right wiskers (contact switches) for buf[3] bit 3 (left) and
' 2 (right).
Get_Whiskers:
'IF FlagWhiskers THEN
buffer3.BIT3 = IN7 ' Left whisker
buffer3.BIT2 = IN8 ' Right whisker
'ENDIF
RETURN
' -----[ Subroutine - Set_Pins ]----------------------------------------------
' Sets up to two pins. buf[3] high nibble specifies the operation, and the
' low nibble specifies the pin. The same applies to buf[4].
' High nibble:
' 0 - no action
' 1 - set to output
' 2 - set to input
' 3 - set to (output-high)
' 4 - set to (output-low)
' Low Nibble:
' 0 to 15 - Specifies I/O pin.
' DO NOT try to set 0, 1, 5, or 6.
Set_Pins:
temp.NIB1 = buffer3.HIGHNIB
temp.NIB0 = buffer3.LOWNIB
GOSUB Op_Pins
temp.NIB1 = buffer4.HIGHNIB
temp.NIB0 = buffer4.LOWNIB
GOSUB Op_Pins
RETURN
Op_pins:
SELECT temp.NIB1
CASE 1
OUTPUT temp.NIB0
CASE 2
INPUT temp.NIB0
CASE 3
HIGH temp.NIB0
CASE 4
LOW temp.NIB0
ENDSELECT
RETURN
' -----[ Subroutine - Delay ]-------------------------------------------------
' Specify delay in ms.
Delay:
temp.LOWBYTE = buffer3
temp.HIGHBYTE = buffer4
PAUSE temp
RETURN
' -----[ Subroutine - Enable_Digital_Sensors ]--------------------------------
' Causes program to put digital sensor values in buf[3] of the reply packet.
Enable_Digital_Sensors:
FlagDigSens = 1
RETURN
' -----[ Subroutine - Disable_Digital_Sensors ]------------------------------
Disable_Digital_Sensors:
FlagDigSens = 0
RETURN
' -----[ Subroutine Enable_Whiskers ]-----------------------------------------
' Causes program to stop the Boe-Bot if Whisker contact is sensed. This gives
' the PC bluetooth system time to reply.
Enable_Whiskers:
flagWhiskers = 1
RETURN
' -----[ Subroutine Disable_Whiskers ]----------------------------------------
' Causes program to ignore the whisker contact. Also ignores when they are
' not connected.
Disable_Whiskers:
flagWhiskers = 0
RETURN
' -----[ Subroutine Enable_Ir ]-----------------------------------------------
' Not implemented.
Enable_Ir:
flagIr = 1
RETURN
' Not implemented.
Disable_Ir:
flagIr = 0
RETURN
' -----[ Subroutine - Maneuver ]----------------------------------------------
' Preprogrammed maneuver example. Current setup allows:
' "U" - Back up then U-turn
' "R" - Back up then right turn
' "L" - Back up then left turn
Maneuver:
FOR temp = 0 TO 35
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
SELECT buffer3
CASE "U"
FOR temp = 0 TO 40
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
CASE "R"
FOR temp = 0 TO 20
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
CASE "L"
FOR temp = 0 TO 20
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
ENDSELECT
RETURN
' -----[ Subroutine Ram_Clear ]-----------------------------------------------
' Clears ram for reset from PC. This prevents retaining the msgIndex and
' pulseLeft/right variable values, which would otherwise cause problems.
Ram_Clear:
W0 = 0
W1 = 0
W2 = 0
W3 = 0
W4 = 0
W5 = 0
W6 = 0
W7 = 0
W8 = 0
W9 = 0
W10 = 0
W11 = 0
W12 = 0
RETURN
what happend to you? the last couple of days you are producing code as if you are posessed by @pullmoll?
Enjoy!
some might say I'm possessed but pullmoll what the heck is that lol.
Jeff T.
@pullmoll is some german forummember (somehow vanished). He was programming - mostly assembler in an astonishing rate. Things like VT100 emulator or z80 emulator.
He is missed here alot. Good to hear from NWCCTV that he is still alive ...
So basicly this was sort of a commpliment. I like your Graphic-Terminal-Thing. I have no current use for but like it somehow.
Enjoy!
