wheelchair motor question
Hi, i have an r/c "buggy" driven by two wheelchair motors. i finally got it working and drove it around for 3 or 4 minutes. there are "cups" on the end of these motors that got twice as hot as the rest of the motor. after this short time i could touch the motor for maybe a second, but couldnt touch these cups at the end they were so hot. there are 2 wires to the motor and 2 to the cup. i thought it was a brake or encoder. this buggy is a scooter chair pretty much without the seat. the controller was bad so i took it off and controlling the motors with relays. does anyone have some info about these end caps im not sure if this is normal or not and dont want to damage anything.-mike
If they are like mine then they are electromagnetic brakes. I removed mine and installed encoders in their place.
You should be able to remove them without affecting the rest of the motor.
If its a stock motor then those are the brakes.
You can easily remove them by taking out a couple of screws.
In an electric wheel chair - when the joystick is moved you will hear a click. That is the electromagnetic brakes releasing. When the joystick goes back to center it will click again when they engage.
http://www.hvlabs.com/hbridge.html
Generally they are micro (μ), nano (n) or pico (p).
http://en.wikipedia.org/wiki/Metric_prefix
I use the Sabertooth 2x25 drive with a Spectrum RC controller.
http://www.youtube.com/watch?v=OQn5SD7UQgw
wheel chair motors with snow blower tracks.
Hehe, but there *are* ultracapacitors, which somehow sound better than sooper-dooper supercaps. These are the ones with, for example, 500-3000 **Farads**. Frankly, I can't even imagine that. They used to say a 1F cap would be the size of a city block. Somehow city blocks got a lot smaller!
-- Gordon
Thanks for posting the hbridge link. I collect those
I see two 680uF, one 1uF, and one 100nF on the schematic. (uF = microfarads, nF = nanofarads)
does anyone have tips on homemade tracks? Also i was wondering if anyone has built their own motor/speed controller. i was going to try the one on the diagram i posted and wondered if anyone had some tips for stuff that may usually go wrong. im relatively new to this stuff and smoked a hip4081 and some mosfets on my first attempt. -mike
You'll need huge batteries, booster cable wiring and starter relays for those motors...
Maybe parts from http://www.tncscooters.com will work for you.
The only time i ever blew a fuse was when i started the motor with one of the brakes on.
That track robot has 20 amp fuses on it and i only used 12 gauge stranded wire for the hook up.
I believe the motor with no load draws less than 1 amp.
I can check it this weekend
W9GFO,
Do you have additional info on the encoder you used, and how you interfaced that with the motor controller?
I have two geared motors from a Jazzy 610 power chair and a Sabertooth 2x25. The motors have that cap on the end with the brake inside. I removed the brakes and think that will be a perfect location for an encoder. I want to incorporate encoders to help with straight-line stability as I will besetting up a bot with differential steering.
falcon
We encountered a problem using the Position Controllers to control the HB-25s. The PID values that are hard coded into the Position Controllers are tuned for the smaller wheels of the Motor Mount and Wheel kit like is found on the MadeUSA or Eddie robots. The massive 13" wheels of my wheelchair based robot would go into oscillations and there was nothing that could be done to fix it. I think it was Kevin (Wood?) at Parallax that spent a couple hours one night during UPEW 2010 trying to get it to work.
The solution is to use the Position Controllers as encoders only - rather than task them with directly controlling the motors.
I did find this place with a selection of encoder wheels . http://www.encodergeek.com/EncoderReaders.html I suppose I could use one of these wheels (since they're cheaper) and find an encoder that would read it.
I've also seen some motor controllers with connections for encoder feedback. Since the 2x25 doesn't have this feature, would I just have to connect the encoder directly to the Propeller and modify the PWM signal based on that feedback? Is that what it boils down to?
Question: I see the wheel-type encoders used in many situation but I haven't seen the rotary encoders like the Parallax P/N 27805 [url] http://www.parallax.com/tabid/768/txtSearch/encoder/List/0/SortField/4/Default.aspx[/url] I'm sure it could be mounted and coupled to the motor shaft under that cap. Is it just not the right type of encoder electrically?
falcon
BTW, if there is a pair of detectors then it is quadrature, if just one LED and detector then it is a tach. The difference is that quadrature gives you four times the number of "counts" per revolution as the tach, and it can tell you the direction it is rotating. A tach only can tell you the speed, it has no way to tell when the direction changes or which direction it is turning.
There are some good quadrature encoder objects in the Obex. Use one of those to have the Propeller monitor the wheel position and speed and then drive the motors accordingly. You'll want to learn about PID (Proportional, Integral, Derivative). You can probably do well just using the "P" (proportional) part so don't think that it is too complicated.
