3.7v 2650 mah li-ion battery
Here is a Link to it
CAT# LBAT-55
$6.50 each
http://www.allelectronics.com/make-a-store/item/LBAT-55/3.7V-2650-MAH-LI-ION-BATTERY/1.html
Also this one
RECHARGEABLE LITHIUM-ION BATTERY, 4.2VDC, 900MAH
http://www.allelectronics.com/make-a-store/item/LBAT-60/RECHARGEABLE-LITHIUM-ION-BATTERY-4.2VDC-900MAH/1.html
CAT# LBAT-60
$2.50 each
CAT# LBAT-55
$6.50 each
Also this one
CAT# LBAT-60
$2.50 each
http://www.goldmine-elec-products.com/prodinfo.asp?number=G15613
Larry
As long the contorler board looks the same
you can remove one and replace it with the one you have BUT make sure that it is for same type of battery also make sure that the battery pack in low state of charge before you do this changing the control boards
I only charge at a rate of 500 millamps and no higher
Post a photo of the control board and the battery you have and I will see if I can help you with it
