ing Emic 2 Module — Parallax Forums
ing Emic 2 Module
xanaduxanadu Posts: 3,347
edited 2012-07-06 22:00 in General Discussion
For fun...
[video=youtube_share;XwKmddSRlsQ]
Sure this was not the best way to go about doing this, but here is the code. I removed a lot of comments in it so be sure to check out the full example code. Another thing to note is I'm running it 20 wpm over regular speed, some clarity is lost for speed.
*Original Header*
│ Emic 2 Text-to-Speech Module: Basic Demonstration       │
│ Author: Joe Grand [www.grandideastudio.com]             │
│ Contact: support@parallax.com                           │
│ See end of file for terms of use.                       │
Program Description:
This program demonstrates the Emic 2 Text-to-Speech Module.
Debug messages are displayed in the Parallax Serial Terminal.
Please refer to the Emic 2 product manual for full details
of functionality and capabilities.
Emic 2 Connections (4 pin male header)
SIN     ────── P6
SOUT    ────── P7
VCC     ────── +5V (VDD)
GND     ──────┐
              GND (VSS)
Revisions:
1.0 (February 14, 2012): Initial release
*CURRENTLY* Modified from original version, use at your own risk!
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
OBJ
  pst       : "Parallax Serial Terminal"                   ' Debug Terminal
  serial    : "FullDuplexSerial"                           ' Full Duplex Serial
PUB main
  serial.Start(7, 6, 00, 9_600)                      ' Start serial port, normal mode, 9600bps
  serial.TX(pst#NL)                                     ' Send a CR in case the system is already up
  repeat until serial.RxCheck == ":"                    ' When the Emic 2 has initialized and is ready, it will send a single ':' character, so wait here until we receive it
  waitcnt(clkfreq / 100 + cnt)                          ' Delay 10mS
  serial.RxFlush                                        ' Flush the receive buffer
  serial.Str(String("N0", pst#NL))                      'voice
  serial.Str(String("V12", pst#NL))                     'volume 18 max
  serial.Str(String("W220", pst#NL))                    'words per minute
  serial.TX("S")
  serial.Str(string("Hello jerk face, thanks for hooking me up!"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("Great i can talk! Now about those sensors?"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/__You took my ping sensor off and never put it back? __You used the ping servo on god knows __what"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/__You never installed the three axis accelerometer! And I still don't feel any rote ary encoders on my wheels"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("/\Let me go off topic for a second, do you know what it's like to move and not know how far you went?"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("i didn't think so! look at you with all these parts and zero time for __me!"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("/\how about some more LEDs or maybe some infrared object detection and GPS"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("i know you have all this stuff laying around, you can't even install the lithium polymer battery"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("/\how about a magnetic compass? or pressure altimeter, __you must like dumb robots!"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("/\/\i could be telling you the tempature and humidity right now but those parts are covered in dust somewhere"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("/\what is going on with my docking station? you said i'd have a docking station, but it looks like you sold out to another robot"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("i think my battery is getting low. Let's see when did you recharge me last? six months ago? a year ago?"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/L O L "))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/\/\/\/i bet you're glad you hooked me up, aren't you?"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/\/\/\/\/\/<<i seem to be feeling kind of slow now"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string("\/\/\/\/\/\/\/\/<<<<<<i'm going to take a nap now, wake me up when i'm finished"))
  serial.TX(pst#NL)
  serial.TX("S")
  serial.Str(string(">>jerk face!"))
  serial.TX(pst#NL)
&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
&#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
&#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
&#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
&#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
&#9474;is furnished to do so, subject to the following conditions:        &#9474;
&#9474;        &#9474;
&#9474;The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.&#9474;
&#9474;        &#9474;
&#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
&#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
&#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
&#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
&#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    edited 2012-07-06 12:13
    I'm in tears!!! This is hilarious and based on your success, I'm cancelling my EMIC 2 order because I really DON'T need this kind of aggravation!!!
    Now we have Robot comics!! It's a brave new world!!!!
  • xanaduxanadu Posts: 3,347
    edited 2012-07-06 12:37
    Thanks Rick I'm glad you liked it. No technology makes me smile as much as robotics.
    This thing is a breeze compared to Speakjet. Speakjet has a unique sound and sound effects, however the Emic 2's voice is very easy to understand, just like computer based TTS. Perfect Paul is the man lol.
    edited 2012-07-06 15:23
    Got mine today........(hiding in basement)
    edited 2012-07-06 15:38
    Wow. This is the first I've actually heard the Emic2 - can't wait to get to Parallax on Monday to check one out.
    Great job, Joe!
    edited 2012-07-06 15:58
    All right, all right - I give in!!! I just ordered one - they are too much fun to ignore!
  • W9GFOW9GFO Posts: 4,010
    edited 2012-07-06 20:15
    Oh I've got to get me one of those!
    Well done xanadu!
    edited 2012-07-06 20:27
    Rich: You can be the first "voice in the sky" talking quadrotor!
    The Goodyear blimps had loudspeakers way back in 1940: http://www.goodyearblimp.com/cfmx/web/blimp/basics/sign.cfm
    edited 2012-07-06 20:55
    That video cracks me up! But what an impressive demo of a very neat new product! 'Hats off to Joe Grand and Parallax. The bar has been raised very high, indeed!
  • jdoleckijdolecki Posts: 726
    edited 2012-07-06 21:08
    yea the Quadrotor could fly over people and ask
    "Who wants a haircut"
    edited 2012-07-06 21:23
    Or this old mac ad would be intresting
    "You like your Propeller better than me don't you Dave"
    http://www.youtube.com/watch?v=nHJkAYdT7qo
    edited 2012-07-06 21:50
    Forgot that in my original post thanks!
    Perhaps Professor Hawking will make a short guest appearance on The Prototypers.
    I need to get one of these on order. Amazing work Joe!
    OBC
