diode needed?
Hi, i have a basic stamp switching n- channel mosfets to turn on/off 12 volt relays. I used the mosfets because they have an internal diode. When tying the stamps ground in with the 12 volt ground do i need a diode to protect the stamp from the coil field collapse, if so what is the correct way to put it in? Thanks-mike
You should always use a diode to dissipate the coil energy when switching relays. For your application, a 1N4001 diode should work. Put the cathode on the +12v side of the relay coil and the anode on the ground side of the relay coil.
No, not across the motors. The diodes protect the driver circuit (i.e. the mosfet and the stamp) but the motors are isolated by the relay. When a relay turns off, the energy in the coil has to go somewhere, and without the diode it will find a path through your circuit and might damage some other components. When a motor turns off, the coil energy is dissipated by the motor slowing down, so no need for a diode. Also, two opposing diodes in parallel will short circuit the motor. .
