Hello World SD file access
Once you have "Hello World" on the screen, time to start loading and saving files to the SD card
Grab a board with an SD card. If it is not on the list, take the text below, edit the SD pins to the ones on your board and save it to a file ending in .cfg and put it in the c:\propgcc\propeller-load folder
Reboot SimpleIDE and your board should be on the list in the dropdown menu.
Change to C++ (my preference)
Memory model to XMMC
Optimization to "speed" (this is going to an SD card so size is not as important as speed).
Run this little program (compiles to about 50k) and it should write some text to a file Test.txt on the SD card.
Click the light blue arrow and it compiles and opens the terminal and should display this
# [propboe] # IDE:SDXMMC clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: eeprom_cache.dat cache-size: 8K cache-param1: 0 cache-param2: 0 eeprom-first: TRUE sd-driver: sd_driver.dat sdspi-do: 24 sdspi-clk: 25 sdspi-di: 26 sdspi-cs: 27
#include <stdio.h> #include <propeller.h> extern _Driver _SimpleSerialDriver; extern _Driver _FileDriver; typedef unsigned char UCHAR; typedef unsigned long DWORD; typedef unsigned long UINT; static char a[80]; static FILE *fp1; /* This is a list of all drivers we can use in the * program. The default _InitIO function opens stdin, * stdout, and stderr based on the first driver in * the list (the serial driver, for us) */ _Driver *_driverlist[] = { &_SimpleSerialDriver, &_FileDriver, NULL }; /** * Main program function. */ int main(int argc, char *argv[]) { strcpy(a,"Test.txt"); // open a file for writing printf("Opening file Test.txt\n"); if((fp1=fopen(a,"w"))==0) fprintf(stderr,"Can't open file %s\n",a); else fputs ("This is a line of text",fp1); fclose(fp1); printf("Text saved and file closed\n"); while(1); }
Loading cache driver Initializing SD card Mounting SD filesystem Opening AUTORUN.PEX Loading kernel Loading cluster map Initializing cache Starting program Opening file Test.txt Text saved and file closed
No need to restart the IDE to reload the board types. Just press the puzzle button.
Cheers.
--Steve
Sorry you're having trouble. Does the program build and load ok?
What is the board type set to?
What is the memory model ?
Maybe post your build status here?
Right-click build status to select all, then right-click again to copy.
Project Directory: C:/Users/Dad/Documents/myProj/
propeller-elf-gcc.exe -o a.out -Os -mlmm -I . -fno-exceptions myProj.c
propeller-elf-objdump -h a.out
Done. Build Succeeded!
propeller-load.exe -I C:/propgcc/propeller-load/ -b C3 -p COM3 a.out -r
Patching __cfg_sdspi_config1 with 090a0b13
Loading a.out to hub memory
29632 bytes sent
Verifying RAM ...
OK
First impression as a user is FANTASTIC PROGRAM!
I am not sure how traditional SPIN or PASM exactly play into this. I really like the program control they offer. Is it possible to build inline code fragments within C?
How do I utilize OBEX code?
I know its early but will there be a C library repository?
sm
Hmm. Seems like the download worked.
What happens if you use a simple hello program?
You might try the SD example here:
https://sites.google.com/site/propellergcc/documentation/libraries#TOC-Console-and-File-system-driver-initialization
Propeller GCC allows using in-line ASM based on the GAS syntax.
Propeller GCC can use PASM code written for a traditional mail-box interface.
Please see the SimpleIDE demo: toggle/pasm_toggle
Propeller GCC does not support the Spin language as a standard feature.
It is possible to start a Spin program from C, but it is an advanced topic.
The code would not be in-line source.
Parallax is working on a set of libraries and training materials.
