ELEV-8 product picture shows props installed incorrectly.
W9GFO
The picture of the ELEV-8 on the product page shows one of the propellers (upper left in the image) going the wrong direction.
The image that appears on the front page has all the propellers going the wrong direction.
Two easy ways to remember the correct rotation;
1. The right front prop turns clockwise, as you go around the machine the direction of each alternates.
2. The inside blades on the front motors sweep forward, the rearward motors' inside blades sweep rearward.
The prop at the upper left is still turning the wrong way.
Both images in my second post show the same prop backwards. Obviously, few people will notice - or care. However it does seem plausible that a user may refer to one of those images to verify proper setup.
