How to use Eddie manifest in VPL?
Hi,
I am new to robotics. I was trying to use Parallax2011ReferencePlatformIoController as service in VPL. When I tried to import EddieObstacleAvoid.user.manifest for this, It is displaying "An error has occurred while manifest is being imported". How do I fix this issue to use manifest in VP?
I have also tried to import Eddie.manifest and EddieObstacleAvoid.manifest but at run time, it showing the following error
Warning: Common Create Handler ExceptionSystem.InvalidOperationException: Service not found: http://schemas.microsoft.com/robotics/2011/08/kinect.html
at Microsoft.Dss.Services.Serializer.DataCache.LoadServiceAssemblies(ServiceInfoType createRequest)
at Microsoft.Dss.Services.Constructor.ConstructorService.CommonCreateHandler(DsspOperation create)
Source: http://127.0.0.1:50000/constructor
Time: 1/07/2012 10:58:18 PM
Info: Rebuilding contract directory cache. This will take a few moments ...
Error: Exception calling service start: System.IO.IOException: The port 'COM4' does not exist.
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
at System.IO.Ports.SerialPort.Open()
at Microsoft.Robotics.Services.SerialComService.SerialCOMService.CreateAndOpenSerialPort()
at Microsoft.Robotics.Services.SerialComService.SerialCOMService.Start()
at Microsoft.Dss.ServiceModel.DsspServiceBase.DsspServiceBase.<StartService>d__52.MoveNext()
Source: http://127.0.0.1:50000/serialcomservice/31e2ee12-1a33-42f0-81b8-7ad5cd5f9f7f
Info: Contract directory cache refresh complete
Time: 1/07/2012 10:58:32 PM
Error: Error creating service. Service type:http://schemas.microsoft.com/robotics/2011/08/kinect.html
Error: Service creation failure most common reasons:
- Service contract identifier in manifest or Create request does not match Contract.Identifier
- Service references a different version of runtime assemblies
Additional information can be found in the system debugger log.
Source: http://127.0.0.1:50000/manifestloader/c6795c61-49ca-46b9-945a-737025f34424
Info: Manifest load complete
Source: http://127.0.0.1:50000/manifestloaderclient
How do I use Eddie manifest in VPL?
Regards
Sumit
Regards
Sumit
