Does anyone see any inherent problems with this PASM code?
I replaced a PASM waitpne with the first few lines of code below and I cannot get consistently accurate results now.
pstPtr6/pstPtr7 will print the cycles I expect to the pst, about 75% of the time, the other 25% it will either print a number smaller than 100 or it will print out a number roughly 2.9 times as big, but never 3 times as large. This seems to be consistent, even when I adjust the frequency going to the input pin.
What I'd like the code to do is test a pin for high and if it is high to go to #end but if the pin is low then the phsa should be done accumulating values for the previous pin high and I should be able to copy the number of cycles out of phsa, so if it is low I then check phsa to see if it is 0. If it isn't 0, I copy the cycles out and store them under highCycles and then set phsa to 0 to show that I've been there so that next time if the pin is low and phsa is 0, I pass by knowing I've already grabbed the cycles data.
I'm not sure what is causing the jitter though, as the routine is pretty simple so I have a feeling I may be missing something obvious. Thanks for reading.
'wait for pin == 0 pause cog until mask matches the second field ' waitpne mask, mask test mask, ina WC, WZ' test pin to be equal to ina register if_c jmp #end ' if equal to to the register jmp to end and loop because you can't count the cycles until the pin is in the opposing state if_z mov phsaT, phsa ' if 0 or not equal to register pin is low, copy cycles measuring pin high to phsaT cmp phsaT, #0 WC, WZ ' compare phsaT to literal 0 if_e jmp #end ' if equal to 0, it has already been checked, jmp to end if_ne mov highCycles, phsa ' copy cycles accumlated to highCycles if_ne mov phsa, #0 ' clear low phase counter if_ne mov risingEdgeCnt, cnt ' store cnt value
You also test both for zero and carry flags after the first test instruction which doesn't make sense - are you trying to test for zero and non-zero? carry records the parity under the mask, unless you actually want to record the parity make things clear by using Z or NZ. Is the mask a single bit or can it be more than one bit?
Why is the waitpne not used? What are you trying to achieve? What is the signal going to the pin and what results are you expecting to observe?
I am not using waitpeq/waitpne because I need to have functionality within the loop where the cog is not paused. The entire code is about 1400 lines so I didn't want to post everything and cause unnecessary confusion with all of the extra lines of code.
Psuedo code line by line would read
Thanks for the code, that was educational! I tried it and it appears to be working like my other code.
I am still seeing "jitter" where phsa and phsb are either <100 cycles or 2.x greater than what they should be. Any thoughts on that?
I have taken out all code in the entire pasm loop but the test command (I'm looping at ~96 cycles in pasm) and I'm still seeing the jitter (both high and low) so I'm going to try something other than test as I'm not sure what else to do.
Is there a command that I can write that clears register flags so that they cannot carry over to the next if_registerflag? Almost like a break? maybe mov 0, 0 ?
Could it be that there is some sort of delay in the frqa to phsa accumulation so that after I detect a pin state transition and I copy the values of phsa to a variable, frqa then loads <100 cycles to phsa which are present the next time I loop through? Is this inherent to the test command?
