potatohead wrote: » What is your hardware? Edit: Well, that driver could be modded to your hardware. Have to see what that is. Or, the technques can be applied to the one you've got cooking too. I really only referenced it, because the buffers and graphics COG interaction in that one are well aligned with what you want to do.
:loop rdlong signal, ptrSignal wz if_z jmp #secondPart jmp #:loop secondPart [.....]
