BST ocmpile error references a blank line!
I tried to attach a screen dump, but for some reason it wouldn't work. Is a TIFF format (on Mac)
I get an 'tv_text (42,8) Error - Unable to locate object' on compile. But, there is no code on or around referenced lines!
Anyone understand what's happening here?
Line 42-44 of tv_text is: If tv.spin were missing, it might be reported with a line number of 42.
Sorry about not incuding any source. Spent about an hour trying to get a part of the screen capture, but wouldn't attach for some reason.
Here's about the first 50 lines of Spin. I have 'tv_text.spin' in the same folder as this source. I'd think it should be easy to figure out but whatever I think up to try, I get about the same error result!
Should there be a tv.spin also included?
Thank you for the info. I keep forgetting to looking into objects to see what other objects might be required. BST unfortunately doesn't provide a list as does the Prop Tool of required files and objects. My bad, again.
I've been having problems with I use Windows via Parallels on the iMac. Everything slows way down and takes minutes to honor a keystroke or selection. I'm trying to move a file, tv.spin, from my Windows side, hoping to drag/drop that file onto the iMac desktop. I get about that far and the 'wagon wheel' cursor just spins for minutes. Almost get the file today. Will have to go back this weekend and try to get it into BST. MOLASSES!
That probably will resolve my problem with the compile error. Just no way to find out right at the moment. Sorry. Stay tuned.
Spent several hours over the past three days and just cannot make much progress when the 'wagon-wheel' cursor spins for minutes before a next operation can occur. That hardly occurs in iMac use, but does way too much in Windows.
All that I could accomplish when trying to drag/drop to iMac desktop would be to make a 'shortcut' copy of tv.spin. Must be something else one has to select to not get that to happen. I must have trashed at least 1/2 dozen copies of tv.spin shortcut. Aggravating. Don't recall when this Molasses stuff began. Because I could use Prop Tool with hardly any delays originally, years back. Don't know if the fault is in Windows XP, Parallels, or iMac operations.
Thank you for pointing that out. When I did either 'tv' or 'tv.spin' the OBEX doesn't show it. Not a very good search engine. Or, is there something else one needs to know to access such a simple file name?
It compiles properly now. My code may not work; I'll find that out tomorrow But assume there will be something to view on a CD player screen.
