Struggling with a simple method for doing digital division (beginner)
Disclaimer: I have had zero formal programming education, and only recently began experimenting with it myself. I decided to go with the propeller based on a friends recommendation. Generally, I've enjoyed the experience, but I have struggled with a few basic concepts, and suspect I may have run into another.
Basically I'm looking for some help with a simple approach to doing digital division. What I have thus far is largely based on Wikipedia's "digital division" article.
I think I've identified two problems with my code. First: I haven't really nailed down how to deal with the quotient; I figured I'd solve my first problem second as my second problem is considerably more confounding. Second: my 'If statement" seems to be running when it shouldn't...
Things seem to work as expected until the 5th run through the loop, or when i=27
So I suppose I'm looking for any help or suggestions anyone has to offer; on this code; learning to code; troubleshooting code; posting on the forums; life.
Thanks for your time.
[B]CON[/B] _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 D=16 N=4 [B]OBJ[/B] pst : "Parallax Serial Terminal" [B]DAT[/B] Q long 0 R long 0 [B]PUB main | i[/B] 'Divide "D"(dividend) by "N"(numerator) and report "Q"(quotient) and "R"(remainder) pst.start(57600) waitcnt(clkfreq*5+cnt) pst.Str(String(13, " ***inputs*** ")) pst.Str(String(13, " D == ")) pst.bin(D, 32) pst.Str(String(13, " N == ")) pst.bin(N, 32) pst.Str(String(13, " Q == ")) pst.bin(Q, 32) pst.Str(String(13, " R == ")) pst.bin(R, 32) pst.Newline pst.Str(String(13, " ***Begin*** ")) if N==0 pst.Str(String(13, " Q = UNDEFINED ")) abort repeat i from 31 to 0 pst.Newline pst.Newline pst.Str(String(13, " i = ")) pst.Dec(i) Values R<<=1 R|=((D and (1<<i))>>i) if R>=D pst.Str(String(13, " R>=D ")) R-=D Q|=(1<<i) [B]PUB Values[/B] 'Display all Variables and their Values pst.Str(String(13, " ***Values*** ")) pst.Str(String(13, " D == ")) pst.bin(D, 32) pst.Str(String(13, " N == ")) pst.bin(N, 32) pst.Str(String(13, " Q == ")) pst.bin(Q, 32) pst.Str(String(13, " R == ")) pst.bin(R, 32) pst.Newline pst.Newline
should be
Good catch. I switched my variable names several times (dividend, divisor, denominator, numerator) depending on which resource I was looking at; guess I got carried away. I'll be sure to sort that out when next I have some time to look at it; but I was in fact attempting to divide D by N, even were it written backwards, I don't think it should be going through the if statement until "i" equals the position of the first 1 in "D"
pik33 was right about the "if R is equal or greater operator."
Unfortunately, I seem to be in even more trouble than I thought I was.
I went through and commented everything to help highlight any foolish errors I may have made. Now I'm running into trouble in the second loop ( i = 30 ).
R should remain 0 until loop 28 when it should be set to 1, then shifted left as the remaining bits are examined until R is greater than or equal to N
Any suggestions would be much appreciated.
to:
Not quite - for division: quotient = dividend / divisor. (Or for integer division: divisor * quotient + remainder = dividend, where the 0 <= remainder < |divisor| )
When talking of a fraction (as a number, not as a calculation) then its numerator / denominator
And a personal post about binary math/bit shifting/dividing: http://tymkrs.tumblr.com/post/19346713047/xbee-led-buzzer-code-analysis-part-5
I couldn't get Wikipedia's "digital division" method to work quite right... based on your original code, in the code section below there is a method implementing a longhand binary division technique that can be found here...
http://courses.cs.vt.edu/~cs1104/BuildingBlocks/divide.030.html
...depending on the size of the divisor and the size of the dividend, the number of itterations will vary to solve the quotent, but will never be more than 31 itterations.
and again, Thank you for your time.
