How to calculate gravity and degree of angle from MEMSIC2125 with C Language?
I can measure ment pulse width with C Languge. But After that I don't know how to calculate it like Basic stamp http://www.parallax.com/dl/docs/prod/acc/memsickit.pdf .
This is pulse width which I can read from MEMSIC2125.
5250 uSec
5060 uSec
5080 uSec
5080 uSec
5070 uSec
I calculate like this formula.
xmG = ((xRaw / 10) - 500) * 8
such as. xmG = ((5250 / 10) - 500) * 8
xmG = 200 ' calc 1/1000 g
= 0.2 'g
If I calculate Tilt = ARCSIN(g) .
= arcsin(0.2)
= 11.536
I don't know it correct or not correct Tilt and gravity value.
How to calculate gravity and degree of angle ?
5250 uSec
5060 uSec
5080 uSec
5080 uSec
5070 uSec
= 0.2 'g
= arcsin(0.2)
= 11.536
#include <stdio.h> #include <math.h> int main(void) { int xRaw, xmG; double gforce; double tilt; xRaw = 5250; xmG = ((xRaw/10) - 500) * 8; gforce = ((double)xmG) / 1000.0; tilt = asin(gforce) * 180.0 / 3.141592; printf("tilt = %lf\n", tilt); return 0; }I ran this on my PC and it produced the same result of 11.536. The C routines compute angles in radians instead of degrees, so you need to do the conversion if you want degrees. I tried compiling this with PropGCC, and the default LMM code does not fit in the 32K hub RAM. I was able to build it using the XMMC model, but I didn't try to trun it. There may be some ways to get this to fit using the LMM model, but I don't know if that's possible with the floating point math routines linked in.
