IIC problem
I've been trying to get this camera working, but I'm having problems addressing it with iic. The device address is 01111000 (if beginning a write command). I don't think I'm receiving an acknowledgement bit. I'm trying to set it up so that it will turn on an LED when the acknowledgement bit is received. So far I've had very little luck. The device is the TCM8230MD. I've also checked the output in GEAR, everything looks fine from the logic probe.
DAT
org 0
camera_control
:counter_control
or dira,extclk
or dira,finpin
movs ctra,#$10
movi ctra,#%0_00100_000
movi frqa,#%00100000_0
:start_cnd
mov time,cnt
add time,wait 'wait for the device to receive enough extclk signals
waitcnt time,delay
or dira,sdapin
waitcnt time,delay
or dira,clkpin
waitcnt time,delay
mov sda_space,data
mov eight,#$0008
:iic_loop
shr sda_space,#1 wc 'OUTPUT=LOW;INPUT=HIGH
muxnc dira,sdapin
waitcnt time,delay
xor dira,clkpin
waitcnt time,delay
xor dira,clkpin
waitcnt time,delay
djnz eight,#:iic_loop wz
:receive
muxnz dira,sdapin
xor dira,clkpin
waitpne sdapin,sdapin
xor dira,clkpin
:doneloop
or outa,finpin
jmp #:doneloop
three long $0000_0003 'number of bytes to send
extclk long $0001_0000 'clock for camera
clkpin long $0004_0000
sdapin long $0002_0000 '
finpin long $0000_8000 'finished
{addresses, data, and vars }
slave_address_read long $0000_0079 'for TCM8230MD
slave_address_write long $0000_0078 'for TCM8230MD
data long $0044_031E 'initialize subQCIF - 16 bits - 0000_0011 <- address 1010_0010 <- command
delay long $0000_00FF 'sets the speed of the iic protocal at around 100_000hz. The maximum speed is 400_000
wait long $0000_FFFF
eight res 1
sda_space res 1
time res 1
fit
1 - is the SCL clock rate running at the appropriate speed for the camera device?
2 - are the SCL and SDA lines pulled high to +5V through resistors (10k)?
3 - is the I2C Start condition being created correctly?
4 - do you have a scope to view the SDA line?
I'm not familiar with the Prop, but a bit familiar with I2C.
the sda and sck lines are pulled high with 2.8V because that's the requirement of the camera. yes, I'm using 10K resistors
yes
no, but I wish I did and I'm considering getting a oscilloscope or logic probe for that general use
I'm starting to think that running 2.8V straight into the RES (active low) might be messing it up, cause I'm not sure if there's any input impedance or not
shr sda_space,#1 wc muxnc dira,sdapin-Phil
edit - it's been using 1E the whole time. i forgot because I wrote this code a few weeks ago.
Can you control the clocking to the camera such that you would be able to stop it at the 9th cycle? This would allow you to check/measure the level of the SDA line, which should be a "low" (ACK/).
edit - thanks though for the suggestion. the datasheet has a power on sequence that I've only loosely followed,
I'm going to change the power on sequence and see if that helps.
