adding board definitions? — Parallax Forums
edited 2012-06-21 04:41 in Propeller 1
2nd post (forum ate the first one)
First of all, excellent work! Installed the Linux version. It was painless and works perfectly!
Second: Question
How do I add a new hardware definition to the board list?
The next run of QuickVGA+ boards includes the SRAM socket as follows:
  • Clk=6
  • Si=7
  • So=8
  • Cs=9
I'd like to play with my prototype while I'm waiting for the restock.
How do I add this?
OBC
  • David BetzDavid Betz Posts: 14,523
    Second: Question
    • Clk=6
    • Si=7
    • So=8
    • Cs=9
    How do I add this?
    OBC
    I assume that these are SPI SRAM chips? If so, you can use the spi_sram_cache.dat cache driver. Here is are the cache parameters that should work:
        cache-driver: spi_sram_cache.dat
        cache-size: 8K
        cache-param1: 0x07080621 # 0xooiiccpp - oo=mosi ii=miso cc=sck pp=cs-protocol
        cache-param2: 0x09000000 # 0xssxxxxx - ss=cs xxxxxx=unused
