Need help getting a encoder index working — Parallax Forums
krazyideaskrazyideas Posts: 119
edited 2012-06-21 11:34 in Propeller 1
So first off just so you know how much of a beginner I am, I just picked up the reference manul and started programing.
Ok so I can reason through Spin sufficently for my little programs and they work :) But when it comes to Assembly, I can't make heads or tails of it :(. I spend about 4 hours today trying with no success.
So now My problem.
I am using a E2 encoder with an index from US digital to run a home made electric motor with my Dad. I got the program running and working, BUT it can only operate at about 1600 RPM. I poked and proded at my program untill I found the part that was causeing the problem.
Which is that my counter (In Spin) can't keep up. So I tryed to convert it to assembly but because assembly is so complicated I ended up looking on the object exchange and found a encoder counter Called "IdxquadDecoder." It's overview says
"Modified Quadrature Decoder object by Luke Hays to use a third pin to preset encoder count to any value allowing the calculation of absolute encoder angle. See Luke Hays' example for reference. The same except uses third pin for index and allows preset by setting the value of BigValue in the asm section of the program."
I got it counting beautifuly, much cleaner then my Spin attempt. But I need the counter or "count register" to be reset to "0" each time the index is triggered, which is once a rotation. I understand in the overview that this is what it does but I can't make it do it.
Can someone point out where in the code I need to change something and please remember I'm clueless.
Here's the Code.
% Quadrature Decoder %
% Author: Luke Haywas %
% Copyright (c) <2010> <Luke Haywas> %
% See end of file for terms of use. %
Description:
Uses one cog to continuously monitor a rotary quadrature encoder.
As the encoder is turned, each change of position is accumulated
to a variable in hub RAM. This variable then reflects how far
the encoder has been turned to the left or the right.
Wiring: Connect the encoder to two adjacent pins. Pass the number
of the first pin as the first parameter of the Start method.
Pass the ADDRESS of the variable to accumulate to as the second
VAR
  byte  cog
PUB start(pin, varaddr)                                 ' Start a cog monitoring the encoder.
  stop
  epin1 := pin
  result := cog := cognew(@quad, varaddr) + 1
  Parameters:
    pin                         first pin of the encoder input
    varaddr                     address of the hub variable to accumulate to
  Returns:
    1 + number of cog it got started in
    0 if no cogs available.
  Note: You can preset the value of the accumulation variable before calling start.
  Example usage:
    variable := 25
    quad.start(12, @variable)
PUB stop                                                ' Stop monitoring the encoder.
  if cog
    cogstop(cog~ - 1)
DAT
                        ORG
quad                 mov     IndexMask, #%100        'Mask for Index Pulse ***
                        shl     IndexMask, epin1             'Shift to proper pin  ***
                        rdlong  accum, par                     ' get initial value of accumulator
                        mov     quadmask, #%11           ' initialize encoder mask
                        shl     quadmask, epin1             ' bitshift it to encoder pins
firstread            mov     oldstate, ina                   ' read encoder for the first time
                        and     oldstate, quadmask         ' call this the "old state"
                        shr     oldstate, epin1                 ' bitshift it into the LSBs
backtostart
                        mov     turnpos, oldstate             ' PURE VOODOO MAGIC
                        rev     turnpos, #30                     ' do some funky bit math
                        xor     turnpos, #%10                  ' new state will match one of these
        ' whichever it matches = turn direction
                        mov     turnneg, oldstate
                        rev     turnneg, #30
                        xor     turnneg, #%01
getnewstate      mov     newstate, ina                             ' read encoder
                        mov     MarkIndex, newstate                 ' Get unmasked index pin ***
                        and     MarkIndex, IndexMask  wz         ' Mask pins other than index ***
              if_z     jmp     #over                                        ' Skip accum 0 if index is 0***
                        mov     accum, #0
over                  and     newstate, quadmask                 ' mask it against the encoder mask
                        shr     newstate, epin1                         ' shift it into the LSBs
                        cmp     turnpos, newstate       wz         ' see if it moved cw
              if_z      jmp     #turnedpos
                        cmp     turnneg, newstate       wz          ' see if it moved ccw
              if_z      jmp     #turnedneg
                        jmp     #getnewstate                           ' falls through, start over
turnedneg          add     accum, #%1
                        wrlong  accum, par
                        jmp     #updatestates                           ' exit
turnedpos          sub     accum, #%1
                        wrlong  accum, par
updatestates     mov     oldstate, newstate                   ' mov newstate overwrite oldstate
                        jmp     #backtostart
epin1   long  12
accum         res 1
quadmask      res 1
oldstate      res 1
turnpos       res 1
turnneg       res 1
newstate      res 1
time          res 1
IndexMask     res 1
MarkIndex     res 1
                        FIT
  • krazyideaskrazyideas Posts: 119
    edited 2012-06-19 22:18
    I tryed to space out the comments so it was easyer to read but then they undid them selves when I posted it. Sorry
    edited 2012-06-19 23:01
    The forum software removes extra spaces unless you use code tags. Phil has posted a tutorial on how to use them.
    edited 2012-06-19 23:34
    I'm not clear on what you want the program to do.
    Do you not want to use the pin to clear the accumulator but to have the accumulator zero itself once a complete revolution has been made?
    If you want to zero the accumulalator once it has reached a certain value, you could add a couple of "cmpsub" statements to the code right before the accumulator is written to the hub.
                            cmpsub  accum, pulsesPerRev
                            wrlong  accum, par
                            cmpsub  accum, pulsesPerRevNeg
                            wrlong  accum, par
    You'd want to add "pulsesPerRev" as one of your PASM variables. You could preset the value of "pulsesPerRev". For example, if your encoder produced 300 pulses per revolution, you'd change the variable section to:
    epin1                   long 12
    pulsesPerRev            long 300
    pulsesPerRevNeg         long -300
    This is the quick way to set a variable value. There are better ways of setting variables than this.
    Edit: I realized you'd need to test for the negative value of pulsesPerRev if the wheel is turning backward. I'm not sure why "turn" labels appear to be opposite in the code.
    BTW, When I added encoder support to my Mecanum wheeled robot, I modified JonnyMac's code from his Spin Zone #6 article. I personally think JonnyMac's code was easier to follow and modify than the code you posted.
    edited 2012-06-20 10:26
    Awsome thanks, for both the code help and for showing me how to display code in the post properly.
    I'll let you know if I get it working today
    And what I really want the to program to do IS to reset the accumulator to Zero each time the index pin is triggered.
    But I think just resetting the accumulator at a certen value will work, not as quite as well because if it was reset each time the index was triggered it would eliminate any possible accumulation errors at the start of each rotation of the encoder.
    I couldn't make the accumulator reset to Zero and I tryed toggleing each pin individualy, but none of the pins reset it.
    Thanks again
    edited 2012-06-20 11:37
    Hi krazyideas,
    carefully looking thru the code I was not able to find any obvious mistakes.
    you are using 3 pins to the propeller ? how did you connect your encoder?
    the PURE MAGIC you found there is actually pretty neat. a quadrature encoder uses 2 signals (the first two pins) to count and decide in which direction to count. So it compares two readouts to find out which signal came first.
    and it checks the third pin and resets the counter to 0 when that third pin is low. But it is adding/subtracting the movment after resetting so you will actually never SEE zero but 1 or -1.
    just put some buttons on a breadboard and test it by hand. IMHO it should work like coded.
    Enjoy!
    edited 2012-06-20 17:35
    Hi Mike.
    So I have the index connected to pin 0. Then the other two pins connected to pin 1 and 2.
    Where it reads
    I am passing pin 1, so in effect it reads
    PUB start(1, varaddr)
    So as I understand it that passes pin 1 and pin 2 to be the inputs from the encoder. But what pin do I connect the index pin to ???? I think I tryed all of them but mabe I missed one.
    Any thoughts?
    edited 2012-06-20 17:36
    Hi Mike.
    Where it reads
    Any thoughts?
  • AribaAriba Posts: 2,693
    edited 2012-06-20 18:54
    looks like the index pin is hardcoded in the PASM code to pin 12. But you can change that to another pin, just modify the number in epin1
    Andy
    edited 2012-06-20 19:10
    Ariba wrote: »
    Andy
    I noticed the "12" also. I don't think it matters though since the start method overwrites the "epin1" value before starting the cog.
    edited 2012-06-20 19:25
    Based on the code in the first post, the index pin is always last in a group of 3.
    quad                 mov     IndexMask, #[COLOR="orange"]%100[/COLOR]        ' Mask for Index Pulse ***
                         shl     IndexMask, epin1        ' Shift to proper pin  ***
                         mov     quadmask, #[COLOR="orange"]%11[/COLOR]          ' initialize encoder mask
    edited 2012-06-20 23:21
    Well I tryed manualy driveing every pin low on the prop other then the two pins (1 and 2) that were connected to the encoders channal A and B. Then after driveing each pin ground I turned the encoder to make sure the count didn't need a step to reset, but it didn't do anything. It just continued to count up or down depending on the direction I turned the encoder.
    I also wrote another little program to make sure that the prop was feeling the index when it went low and high, by turning a LED on and off through the prop based on the condition of the index pin. It worked fine.
    This is the demo program I have been useing to read the value of the count
    % Quadrature Decoder DEMO %
    Description:
    Demonstrates how to use my object QuadDecoder.
    Quadrature encoder is connected to pins 1 and 2.
    (If connected to different pins, simply change the
    value of ENCODER_PIN below)
    Displays value of the accumulated variable in
    the serial debug terminal.
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      '_xinfreq = 6_250_000
      LCD_PIN       = 27
      LCD_BAUD      = 19_200
      LCD_LINES     = 4
      LCD_COLS      = 20
      ENCODER_PIN   = 1
    OBJ
      quad  :       "IdxQuadDecoder"
      db    :       "FullDuplexSerial"
    VAR
      long  count                                          ' example variable that will be accumulated to
    PUB main
      db.start(31,30,0,115_200)                             ' crank up the debug terminal
      count := 25                                          ' initialize the accumulator
                                                            ' You can set it to any desired value
      quad.start(ENCODER_PIN, @count)                      ' start the encoder reader
      ' output to debug terminal:
      repeat
        db.str(string(1, "Quadrature Decoder Demo", 13))
        db.str(string("-----------------------", 13, 13))
        db.str(string("Value = "))
        db.dec(offset)
        db.tx(32)
        waitcnt(clkfreq/10 + cnt)
    I've tryed everything I can think of.
    edited 2012-06-20 23:43
    krazyideas wrote: »
    The code you posted resets the count when the index pin is driven high, not low.
            mov     accum, #0
    edited 2012-06-21 06:41
    Thanks. I will try driveing each pin High and see what happens.
    I can really see the advantage of assembly vs spin but where would a fellow go for a couple of really good tutorals that explained thins well?
    Thanks again
    edited 2012-06-21 06:42
    Thanks again
    edited 2012-06-21 07:31
    If you're using P1 and P2 for the encoder, then P3 would be the reset pin.
    The line before "over" sets the accumulator to zero. If P3 is low, this line gets skipped (the z flag would be set by the "and" statement, so "if_z" is true), if P3 is high the variable "accum" is set to zero.
    IT WORKS, Awsome.
    Thank you guys so much for the help. And the patience with a begginer.
    You guys are great.
    Take care
