Building propgcc on ARM.
Heater.
In an idle moment I tried building propgcc on an ARM board. An ISEE IGEPv2 board like this: http://www.isee.biz/products/processor-boards/igepv2-board
IOf course the rebuild.sh failed. Somewhere in building the info documentation files. Seems the Linaro version of Ubuntu I have running on this machine does not have texinfo or some such installed. After chasing around for a bit a ran out of time to figure out how to get texinfo dev packages on their.
Sorry I don't have the actual failure messages to hand at the moment. Perhaps I'll find time to go through that again at some point.
Anyway, I was just wondering if anyone knew of a magical switch that would stop the build system from trying to build the info documents, after all I don't really want them on my ARM board.
I too would like to not build the texinfo stuff, and suspect it may have to do with configure finding one or more packages on the system. The only other package problem i've had is with terminfo - installing ncurses dev package fixes that on debian
I was thinking about trying to build pgcc and SIDE for it. I'm pretty sure that I could use it to build natively on ARM, SIDE might be a stretch though.
It works about the same speed as an Atom processor Linux netbook. Dual core 1.2Ghz with 1GB of RAM. And I finally have access to a REAL environment outside of Android!
Some erroneously refer to it as Linux ontop of Linux ontop of android, but it's actually Debian with the Android runtime on top, then Ubuntu chrooted in another location, but all 1 kernel and memory space.
Amazing what you can do on a phone now a days.
I suspect it should be possible to build SIDE there. SIDE is written in C++ using the Qt graphical user interface libraries. I have had success getting Qt based applications running on ARM boards. I also have Qt based programs running on Android on a Samsung Galaxy S.
the race is on... acually if u get gcc and proploader on arm first comgrats! i can test my hardware quicker!
You could make a desktop computer that ran Android natively, doing the same thing.
The reality is that Android is a Java runtime that provides an API and a visual interface, not just widgets. Java has the ability to run with many different frontends, whether it's X, MSWindows, or a smartphone. Google decided to build on top of Linux. I think they either use a tiny X server implementation for the phone, or a custom purposed graphical engine.
Ive also noticed anything i have compiled in the chroot enviroment will run on the andoid command line too, so basically you dont even need the android ndk to make android command line apps, just a tip
Motorola is running a native debian distro on the phone, with Android running on top of it. They installed an X server and a minimal runtime environment for Firefox and Gnome. I installed an image from the eternity project, which contains a full debian/ubuntu 11 installation.
I've got a shortcut on the apptray that mounts the image and chroot, and launches gnome-panel. The panel is on the right side of the screen and allows me to launch any debian/ubuntu application on the phone.
The HDMI output of the phone drives the LCD display and the USB port goes into host mode, providing access to 2 USB ports on the back, USB keyboard, and USB trackpad.
This effectively turns the RAZR into a dual core laptop with 1GB of RAM, 4G wireless, WiFi, and all the other doodads.
The LCD is 1366x768 and android is run in a window that can be resized and such.
