Please Help - How Can I Match One Color? I will do the rest, but I need help getting
Hi,
I connected a TCS 3200-DB Color Sensor to my Board ofEducation Bs2, and got the LEDs working, thanks to the wonderful help I gothere.
I amtrying to use the sensor to distinguish among different objects, yellow, red orblue. The color of each object was calculated with the sensor and it is alreadyknown. For example, Yellow gives avalue of he color of: R041 G025 B011 when I use the code lines DEBUG "R", DEC3 RED; DEBUG "G", DEC3 GREEN; and DEBUG " B", DEC3 BLUE.
Using just one colorand one object as an example, I entered as EEPROM data this line: CYel DATA 186, 155, 058 ' yellow. But, I cannot get the values inputted by the sensor to compare with theEEPROM. Assuming RED, GREEN, and BLUEare the inputted sensor data of the object I was going to use IF RED + GREEN + BLUE = CYel THEN DEBUG"Yellow", and IF RED + GREEN + BLUE <> CYel THEN DEBUG "NoMatch".
But, all I get is a big mess. I looked through the M Sorter program and that just got me moreconfused. So that program does not have any help, in fact I tried to run it and also had total failure. Sorry, I am in grade 8 and Iseem to be getting easily confused as I try to spend most of my time doingsummer homework. I have tried to solvethis every way I can, but it just does not work. I feel like a total failure.
Can someone please help me with a few lines of code for onlyone color? I will do the rest, and theninstead of DEFRAG, I will make a pin active so I can control another devicewith a relay. I have gotten that partowrking as a module, but little good that does me, when I cannot get past thisMatching Color issue! And, I do notcare about white balance, that only further confuses this, I will learn thatand do a better and more in depth program later this summer, after I get thissimple version working. Can someoneplease help me with a few lines of code for comparing a color read by the TSCand a known color in EEPROM and how to compare them to see if that objectmatches the EEPROM color I had loaded??
Thank you for your help,
Rory
Rory
However, I do not know how to write the code to bring the raw data up and to compare it with what I have stored. In fact, I get 3 digits when I use DEFRAG Dec 3 red, but if I use just DEFRAG red I only get a weird symbol. I need to get the data from the sensor, but how? What does it really look like (I only can see it with DEC 3)? How can I compare that with 041 025 011 , since that is really 3 signals in one DEFRAG, i.e., DEFRAG Dec 3 red, Dec 3 green, DEC blue? There must be a way to compare the relative color valuses for red, green and blue sent for each block scanned, but they are 3 values, so what do I do when my EEPROM has one line with all 3 values on the same line? I am totally lost on this - I have worked very hard, but I cannot figure this out. Can someone please give me some code lines so that I can dothis with one color?
I am using this program to get my data, but I need to do more than display the data on a DEFRAG screen, I need to compare the data with known data that I load in EEProm. Please, help me solve this, thanks, Rory
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
OUT PIN 2 ' C
LED PIN 3 ' D
S2 PIN 4 ' E
S3 PIN 5 ' F ' Thanks Mr Phil for helping with the pins, I never could do this without you
[ Constants ]
Define COUNT periods
pRED CON 13 'Red reading period.
pGREEN CON 12 'Green reading period.
pBLUE CON 11 'Blue reading period.
[ Variables ]
RED VAR Word 'Red color reading.
GREEN VAR Word 'Green color reading.
BLUE VAR Word 'Blue color reading.
counter VAR Byte
[ Initialization ]
HIGH LED 'Turn on LED
[ Program Code ]
FOR counter = 1 TO 2
GOSUB Color 'Get the color data, and output to DEBUG.
DEBUG "R", DEC3 RED
DEBUG " G", DEC3 GREEN
DEBUG CR
NEXT
' No pause after the Dark runs
HIGH LED
PAUSE 100 ' want to wait before sensing starts
FOR counter = 1 TO 4
DEBUG "R", DEC3 RED
DEBUG CR
NEXT
PAUSE 10
'Repeat color sensing, it more accurate re-doing and use last run data
DEBUG "R", DEC3 RED
DEBUG CR
NEXT
LOW LED
' Now Rory makes other relay flash & then END program
LOW 13 ' Relay Off
HIGH 13 ' Relay On
PAUSE 300
LOW 13 ' Relay Off
END
[ Subroutines
' Color: Read all three color components.
Color:
LOW S2 'Address the red output.
LOW S3
COUNT OUT, pRED, RED 'Read the red component.
HIGH S3 'Address the blue output.
COUNT OUT, pBLUE, BLUE 'Read the blue component.
HIGH S2 'Address the green output.
COUNT OUT, pGREEN, GREEN 'Read the green component.
RETURN
Thank you for the help, using an array to remove the "odd-ball" readings will help when I get this color matching code writing issue solved. Thank you, Rory
I hope you realize this array is not just to remove the oddball readings, but how you would determine the color.
Here is how you would find the closest match.
