QTI
Hi
I have problem in QTI Line Following,i use boe-bot and BS2,i use pins 12,13,14,15
but my test code does't work..........
QTI TEST (2).bs2
waiting for reply
nihal
QTI TEST (2).bs2
waiting for reply
nihal
Thanks mr:mike green for reply
but my problem is ......the documentation use pin 4,5,6,7 when i change other pin like 12,13,14,15the sensor don't work
"i mean that the sensor work just on the pins used in documentation"
.....................My attachment code is the same code in documentation............
but just change the OUTB,DIRB,INB to OUTD,DIRD,IND
X4 and X5 Sockets is number 5 in the attached image
