Msrds 4
Has anyone out there worked with MS Robotics Studio Version 4? I just downloaded and I was hoping there was spport for a BoeBot but I can not seem to find it. I know in the older version there was a patch that would make it work. Any how, I want to use this along with a BS2 and an ITX based mini computer to build my bot. It would be nice if there was an easy way to implement the BoeBot in MSRDS!!!!!
the info you need can be found here....
http://forums.parallax.com/showthread.php?138582-BoeBot-Connection-to-MSRD-R3-R4
also did one thread for the Propeller chip (Quick Start Board).....
more info on the bluetooth modules can be found here....
EZbluetooth..
http://forums.parallax.com/showthread.php?112822-How-to-–-Boe-Bot-Robot-with-Easy-Bluetooth-Module&highlight=eb500
and A7 eb500 info here...
http://forums.parallax.com/showthread.php?108589-How-to-Boe-Bot-Robot-with-eb500-Bluetooth-Transceiver-Module&p=769239#post769239
hope this helps.....
I was wondering if any of you guys has succesfully connected the boe bot with MSRDS with the easy bluetooth module?
I haven't, I was in the middle of research, when I came across the A7eb301's bluetooth's... it can be done, you just have to write the MSDRS R4 code; you can take snippets from the current version and rewrite some of it. You can find some A7eb301's in ebay I think...
