SD Socket, Write Protection and Card Detection?
rwgast_logicdesign
Ok so a while back i just soldered and sd card to some headers, I haven't had the need for SD before today and realized theres no way I wan Insert that SD card soldered to headers into my pc... the hole header idea looks cool and thrifty but its kind of useless. Anyways I have some molex SD socket, problem is I dont know the part number or anything about them, but Im assuming there fairly standard without card detection since theres 9 pins. This is what I have put togather so far
Now I was going to attach 10k pull ups to be on the safe side, then I started thinking is there any way to do card detection and most importantly write protection detection by adding some components. Ray says he can do card detection with 4 resistors but i looked at his PSM document that he refers too and the schematic in the SD section doesnt show anything except connections on p0-3.. That also doesnt take care of the write protection either.. just thought id check before i start soldering things togather. I would think card detection could easily be done via software but i have no idea how to check the wp tab..
when building this thing i realized i wanted a status led would the best way ti achieve that be to tie an led to the cs line or the io lines?
