Bug in printf with long long handling
pedward
As a simple test, I modified the hello.c as follows:
The result is garbage for the second value. Now, %x only handles longs, but it appears that the stack is not properly managed by the printf function.
What happens:
String is pushed onto stack
Low long of n is pushed
High long of n is pushed
printf is called
Here's the PASM listing:
The observed behavior is the low long of n is displayed with first %x, but for the second %x it is gibberish. The expected behavior is that the low long of n should be displayed with spaces separating.
As a test, I replaced the second n with 0 and got the expected result, 4 items are placed on the stack in that instance.
If I just put n as the argument, I get similar gibberish, so it's consuming both longs.
My original intent was to print the high long using this syntax:
#include <stdio.h>
#include <propeller.h>
int main(void)
long long n = 1;
printf("Hello World\n");
while(1) {
waitcnt(CLKFREQ/10+CNT);
printf("Hello World %x %x\n", n, n);
n+=0x0FFFFFFF;
return 0;
What happens:
printf is called
17:hello.c **** printf("Hello World %x %x\n", n, n);
55 .loc 1 17 0 discriminator 1
56 0068 009C3C08 wrlong .LC4, sp
57 006c 0000BCA0 mov r7, sp
58 0070 0400FC80 add r7, #4
59 0074 0000BCA0 mov r6, r14
60 0078 0800FC84 sub r6, #8
61 007c 0000BC08 rdlong r6, r6
62 0080 00003C08 wrlong r6, r7
63 0084 0400FC80 add r7, #4
64 0088 0000BCA0 mov r6, r14
65 008c 0400FC84 sub r6, #4
66 0090 0000BC08 rdlong r6, r6
67 0094 00003C08 wrlong r6, r7
68 0098 0000BCA0 mov r7, sp
69 009c 0C00FC80 add r7, #12
70 00a0 0000BCA0 mov r6, r14
71 00a4 0800FC84 sub r6, #8
72 00a8 0000BC08 rdlong r6, r6
73 00ac 00003C08 wrlong r6, r7
74 00b0 0400FC80 add r7, #4
75 00b4 0000BCA0 mov r6, r14
76 00b8 0400FC84 sub r6, #4
77 00bc 0000BC08 rdlong r6, r6
78 00c0 00003C08 wrlong r6, r7
79 00c4 0000FC5C jmpret lr,#_printf
printf("Hello World %x %x\n", *(&n+4), n);
As Dave said, %llx can be used to print a long long. If you really want to print the two halves separately, use casts and do something like:
printf("value = %x %x", (long)n, (long)(n>>32));If you look at the assembly listing, you will see that GCC didn't do any magic, it did as it should and passed 5 longs on the stack. The problem is in printf handling the passed variables.
I tested with the "not" simple printf, and it does the same thing.
If I pass "n, 0" as the parameters, the first invocation of printf prints "1 0", then each subsequent invocation prints garbage for the second argument.
The output for ersmiths suggestion results in garbage in the "(long) (n>>32)" position.
17:hello.c **** printf("Hello World %x %x\n", (long)(n>>32), (long)n); 63 .loc 1 17 0 discriminator 1 64 0078 0000BCA0 mov r7, r14 65 007c 0400FC84 sub r7, #4 66 0080 0000BC08 rdlong r6, r7 67 0084 0000BCA0 mov r12, r6 68 0088 0000FC38 sar r12, #0 69 008c 0000BC08 rdlong r7, r7 70 0090 0000BCA0 mov r13, r7 71 0094 1F00FC38 sar r13, #31 72 0098 0000BCA0 mov r5, r12 73 009c 0000BCA0 mov r7, r14 74 00a0 0800FC84 sub r7, #8 75 00a4 0000BC08 rdlong r6, r7 76 00a8 009C3C08 wrlong .LC4, sp 77 00ac 0000BCA0 mov r7, sp 78 00b0 0400FC80 add r7, #4 79 00b4 00003C08 wrlong r5, r7 80 00b8 0000BCA0 mov r7, sp 81 00bc 0800FC80 add r7, #8 82 00c0 00003C08 wrlong r6, r7 83 00c4 0000FC5C jmpret lr,#_printfThe code above shows quite clearly that there is some screwy stuff going on with printf and the stack. I would bet that the stack will keep growing until the program crashes.
#include <stdio.h> #include <propeller.h> int main(void) { long long n = 1; printf("Hello World\n"); while(1) { waitcnt(CLKFREQ/10+CNT); printf("Hello World %llx %llx\n", n, n); n+=0x0FFFFFFF; } return 0; }When I changed to LMM and "standard printf" the results were as expected.
That said, there is still a bug.
In COG MM, using simple printf, when casted to a long and shifted, the results are not as expected.
In LMM, using simple printf, when casted to a long and shifted, the results are as expected.
Clearly there is something wrong with simple printf in COG MM.
I note that in your assembly code there's a "jmpret lr, #_printf". That implies that you're compiling for the COG memory model, which is pretty significant, because it uses a different library. That library only has the simple printf; in fact it's a stripped down version of the full printf. So 64 bits aren't handled.
http://propgcc.googlecode.com/hg/doc/Library.html#printf
#include <stdio.h> #include <propeller.h> void main() { long long test; test = 0x12345678abcdef0LL; printf("test = %x %x\n", (unsigned int)test, (unsigned int)(test>>32)); test++; printf("test2 = %x %x\n", (unsigned int)test, (unsigned int)(test>>32)); }I tried your same syntax in the hello.c program and it still doesn't work properly.
I would appreciate it if people would try to replicate my findings with the code I provided above, instead of telling me 5 different ways of trying to do it otherwise. My syntax isn't wrong, the compiled code is not working correctly. I want to fix or document this problem, not ignore it.
The first step in fixing something is to replicate the result, given the input. If the input is insufficient to replicate the result, then goto 0.
I have narrowed it down to simple printf not behaving correctly in COG mode. The "(unsigned int)(n>>32)" syntax DOES NOT work in the hello.c example I cited above.
I'm not trying to be contrary, I'm trying to get to the bottom of what I see as a bug, because it doesn't pass the simplest of examples.
This was prompted by the 64bit math thread, I wanted to simply demonstrate 64bit variable handling, and it has failed.
I agree. I've tried all the examples here and the only ones i can get to work are:
Eric's simple_printf LMM example, and peward's non simple_printf LMM example.
These were all run with simpleide on linux (pita not being able to simply disable output).
Here are some output samples:
SimpleIDE Eric's example:
peward example with no simple_printf on LMM
peward example with simple_printf on LMM
peward example with COG mode
Where is the source to the simple printf located? I'm assuming that there are multiple libraries for it, one for COG MM and one for xMMy?
I tried compiling your sample program (the first one in the thread) exactly as given, and it worked for me. The code was:
#include <stdio.h> #include <propeller.h> int main(void) { long long n = 1; printf("Hello World\n"); while(1) { waitcnt(CLKFREQ/10+CNT); printf("Hello World %x %x\n", n, n); n+=0x0FFFFFFF; } return 0; }I don't have simple IDE. The command line I used to compile was:
and the output was:
Note that the code as given is not legal C, since we're passing 2 long longs in to printf but the format string is told to expect only unsigned ints. So in theory the results could be undefined and I just happen to be getting the right answer where you are not. We could try modifying the code to be strictly C compliant, which would be:
#include <stdio.h> #include <propeller.h> int main(void) { long long n = 1; printf("Hello World\n"); while(1) { waitcnt(CLKFREQ/10+CNT); printf("Hello World %x %x\n", (unsigned int)(n>>32), (unsigned int)n); n+=0x0FFFFFFF; } return 0; }Does that work for you?
.balign 4 .LC1 long -1698898192 long 305419896and then loads it with something like:rdlong r13, .LC2 .... .LC2 long .LC1+4But this requires that .LC1 must be in hub memory in order to work properly, and it looks like in -mcog mode the compiler puts it into cog memory.
It should just emit directly in -mcog mode. I'll look into it.
1 .text 2 .Ltext0 3 .data 4 .balign 4 5 .LC0 6 0000 48656C6C .ascii "Hello World\0" 6 6F20576F 6 726C6400 7 .balign 4 8 .LC3 9 000c 48656C6C .ascii "Hello World %x %x\12\0" 9 6F20576F 9 726C6420 9 25782025 9 780A00 10 001f 00 .text 11 .balign 4 12 .global _main 13 _main 14 .LFB0 15 .file 1 "hello.c" 1:hello.c **** /* 2:hello.c **** * This demo uses waitcnt instead of sleep so it will fit in a COG. 3:hello.c **** * It also repeats printing every 200ms and prints the iteration. 4:hello.c **** * Some computers may not be fast enough for the terminal to catch 5:hello.c **** * the serial input after loading the Propeller, so you may not see 6:hello.c **** * "Hello World 1", but you will see something on the terminal. 7:hello.c **** */ 8:hello.c **** #include <stdio.h> 9:hello.c **** #include <propeller.h> 10:hello.c **** 11:hello.c **** int main(void) 12:hello.c **** { 16 .loc 1 12 0 17 0000 0400FC84 sub sp, #4 18 .LCFI0 19 0004 00003C08 wrlong r8, sp 20 .LCFI1 21 0008 0400FC84 sub sp, #4 22 .LCFI2 23 000c 00003C08 wrlong r12, sp 24 .LCFI3 25 0010 0400FC84 sub sp, #4 26 .LCFI4 27 0014 00003C08 wrlong r13, sp 28 .LCFI5 29 0018 0400FC84 sub sp, #4 30 .LCFI6 31 001c 00003C08 wrlong r14, sp 32 .LCFI7 33 0020 0400FC84 sub sp, #4 34 .LCFI8 35 0024 00003C08 wrlong lr, sp 36 .LCFI9 37 0028 0000BCA0 mov r14, sp 38 .LCFI10 39 002c 1400FC84 sub sp, #20 40 .LCFI11 13:hello.c **** long long n = 1; 41 .loc 1 13 0 42 0030 0100FCA0 mov r6, #1 43 0034 0000BCA0 mov r7, r14 44 0038 0800FC84 sub r7, #8 45 003c 00003C08 wrlong r6, r7 46 0040 0000BCA0 mov r7, r14 47 0044 0400FC84 sub r7, #4 48 0048 0000FCA0 mov r6, #0 49 004c 00003C08 wrlong r6, r7 14:hello.c **** printf("Hello World\n"); 50 .loc 1 14 0 51 0050 4C00BCA0 mov r7, .LC1 52 0054 0000BCA0 mov r0, r7 53 0058 0000FC5C jmpret lr,#_puts 54 .L2 15:hello.c **** while(1) { 16:hello.c **** waitcnt(CLKFREQ/4+CNT); 55 .loc 1 16 0 discriminator 1 56 005c 4D00BCA0 mov r7, .LC2 57 0060 0000BC08 rdlong r7, r7 58 0064 0000BCA0 mov r6, r7 59 0068 0200FC28 shr r6, #2 60 006c 0000BCA0 mov r7, CNT 61 0070 0000BC80 add r7, r6 62 0074 0000FCF8 waitcnt r7,#0 17:hello.c **** printf("Hello World %x %x\n", (unsigned int)(n), (unsigned int)(n>>32)); 63 .loc 1 17 0 discriminator 1 64 0078 0000BCA0 mov r7, r14 65 007c 0800FC84 sub r7, #8 66 0080 0000BC08 rdlong r5, r7 67 0084 0000BCA0 mov r7, r14 68 0088 0400FC84 sub r7, #4 69 008c 0000BC08 rdlong r6, r7 70 0090 0000BCA0 mov r12, r6 71 0094 0000FC38 sar r12, #0 72 0098 0000BC08 rdlong r7, r7 73 009c 0000BCA0 mov r13, r7 74 00a0 1F00FC38 sar r13, #31 75 00a4 0000BCA0 mov r6, r12 76 00a8 009C3C08 wrlong .LC4, sp 77 00ac 0000BCA0 mov r7, sp 78 00b0 0400FC80 add r7, #4 79 00b4 00003C08 wrlong r5, r7 80 00b8 0000BCA0 mov r7, sp 81 00bc 0800FC80 add r7, #8 82 00c0 00003C08 wrlong r6, r7 83 00c4 0000FC5C jmpret lr,#_printf 18:hello.c **** n+=0xFFFFFFF; 84 .loc 1 18 0 discriminator 1 85 00c8 0000BCA0 mov r7, r14 86 00cc 0800FC84 sub r7, #8 87 00d0 0000BC08 rdlong r5, r7 88 00d4 0000BCA0 mov r7, r14 89 00d8 0400FC84 sub r7, #4 90 00dc 0000BC08 rdlong r6, r7 91 00e0 4F00BCA0 mov r3, .LC5 92 00e4 5100BCA0 mov r7, .LC6 93 00e8 0000BC08 rdlong r4, r7 94 00ec 0000BCA0 mov r7, r5 95 00f0 0000BC80 add r7, r3 96 00f4 00003C85 cmp r7, r5 wc 97 00f8 0000FCA0 mov r2, #0 98 00fc 0100FC70 muxc r2,#1 99 0100 0000BCA0 mov r8, r6 100 0104 0000BC80 add r8, r4 101 0108 0000BCA0 mov r6, r2 102 010c 0000BC80 add r6, r8 103 0110 0000BCA0 mov r8, r6 104 0114 0000BCA0 mov r6, r14 105 0118 0800FC84 sub r6, #8 106 011c 00003C08 wrlong r7, r6 107 0120 0000BCA0 mov r6, r14 108 0124 0400FC84 sub r6, #4 109 0128 00003C08 wrlong r8, r6 19:hello.c **** } 110 .loc 1 19 0 discriminator 1 111 012c 17007C5C jmp #.L2 112 .LFE0 113 .balign 4 114 .LC1 115 0130 00000000 long .LC0 116 .balign 4 117 .LC2 118 0134 00000000 long __clkfreq 119 .balign 4 120 .LC4 121 0138 0C000000 long .LC3 122 .balign 4 123 .LC5 124 013c FFFFFF0F long 268435455 125 0140 00000000 long 0 126 .balign 4 127 .LC6 128 0144 40010000 long .LC5+4 190 .Letext0 191 .file 2 "/opt/parallax/propgcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/includI was able to initialize a 64bit value and shift it to print the upper and lower longs. I'm in the process of rebuilding the compiler from scratch, my local repo was dorked and I had to re-clone the repo. I got half way through building the tools and it bombed out on the library. Oops, bombed out again, off to make another post...
Thanks for bringing this issue to our attention.
