Jeff's Retrocomputer
Dr_Acula
I've been checking out Jeff's board and Basic over on Gadget Gangster http://www.gadgetgangster.com/news/56-jeffs-shop/546-retro-style-pocket-mini-computer.html
All pretty nifty!
Looking at the code, it looks like there is 12k free for code space. Considering space is needed for the VGA buffer and all the code running things, that is pretty impressive given the memory constraints of the propeller memory.
Is the source for the Basic interpreter available? On the links I could only find binary files.
All in all a very clever propeller demo. Well done to all those involved.
All pretty nifty!
More specifically, here
What an amazing project!
The 'core' of the program is the texec function - that processes all the lines.
I've just been writing a whole lot of string drivers for the touchscreen board. It has taken a few weeks and hasn't been very exciting as there is nothing to really show for it as yet. But there is now a library of string drivers that work with external ram. Some things like loading a file off SD card and into a string array can be done with one instruction. Useful for reading files into a text editor, or reading in and processing .ini type files. External string arrays are very useful as there is up to a megabyte of space for strings. I've got this idea that instead of the code in this thread fetching each line from hub ram, it can fetch each line from external ram. That is just one instruction per line to fetch. Programs could be thousands of lines long.
And another crazy idea - many lines of code in Basic are rather similar to Spin. There could be scope for a spin interpreter as well. It could be one path to big (albeit slow) spin.
Back to coding...
'' Propeller VGA BASIC COLOR V2.2
'' By Jeff Ledger
'' Do not attempt to grab objects from this package as many have been
'' altered to remove methods which were not used in this project to
'' conserve all possible memory for the BASIC enviroment.
''This software would not have been possible without help and contributions from:
''* Mike Green (FemtoBASIC)
''* Tomas Rokicki (FemtoBASIC, & FSWR)
''* Marko Lukat (Despair & Hope VGA driver)
''* Pat Daderko (Wii Controller driver)
''* Johannes Ahlebrand (TinySynth)
''* Michael Park (Edit)
Maybe Andre' can use it.
I really felt it was important to credit all of the code contributions up front. If I've missed anyone, please let me know.
I'm seriously considering a version of this which uses the 32K SRAM for program storage, but I've got two other required projects to finish as well as three other demo projects on my list before I'll get to it. One of the interesting things that the SRAM addition would do is create the necessity for PEEK, POKE, and DATA statements, so I'm pretty excited about getting into it soon.
OBC
Andre' has quite a long list of requirements. :-)
OBC
Take your time. As long as it's all done in time to demo at UPEC.
199: 'FILTER a:=expr fil:=a*21That doesn't make any sense! What's up with "fil:=a*21" ?
"fil:=a" makes more sense, but only a value of 0 to about 12 gives audiable results. more than 12 will give a cutoff frequency so low that almost nothing will get trough.
I can't see a token to set the decay rate, that's more important than be able to set the attack rate.
Btw, did I say that I really like this project?
I would recommend staying away from the SRAM, since it's not part of most Prop boards. However, I think it would be useful to make it use the upper 32KB of EEPROM that most boards *do* have.
If you wrote a smart cache driver for it, you could get reasonable performance.
If you tokenized the BASIC first, then stored the tokens, and when editing it, "decompile" the tokens into the editor, that would save space.
LOL! Thanks for the feedback! There is a token to set decay, but it's buried in a another section above the other commands. (It replaced an original Femto command which I retired)
I need to find a way to get the newer version of your TinySynth into this. I'm counting every byte as this point.
OBC
197: 'NOTEOFF synth.noteOff(0)LOL
Edit Fixed! http://forums.parallax.com/showthread.php?140194-PROPELLER-COLOR-BASIC-(was-VGABASIC)
That sounds interesting. I think that might have been how Micro-Soft MBASIC worked back in the 1970s. The conversion to tokens would be done as each line is entered on the editor so the time delay would not be great there. I recall you could save and load off the disk in the tokenized format (faster) or as proper text (slower and larger but able to be edited by another text editor). I think it was SAVE "MYFILE" or SAVE "MYFILE",A and loading would read either format.
OBC already has tokens in the code with the numbers he uses.
