problem understanding the results with the quickstart board
I was playing around with this code to illustrate a problem in another thread related to not being able to have the same variable name in two assembler routines in one file.
Just for the heck of it, I loaded it and this illustrates a consistency problem I've been having.
1) As below, I would expect the first asm routine to load with cognew, set the quickstart low order leds on, then loop. The expected output would be 4 bright lights.
2) Then the second routine is loaded with cognew and the output should be two of the higher order leds on at a lower brightness and pulsing that I read with a scope.
What happens though, is the first loads, the second loads, I get the low order lights on as in (1) and the alternate lights on in (2) then after about a second, the high order (alternating) lights turn off.
If I swap the cognew statements I get different results.
Can someone load this on a quickstart and see if you get the same results?
VAR long X long Y long stack1 long stack2 Pub Start cognew(@start1, @stack1) cognew(@start2, @stack2) repeat x:=Y DAT org 0 start1 or dira, allleds or outa, leds loop1 jmp loop1 leds long $0F<<16 allleds long $FF<<16 org 0 start2 or dira, allleds2 loop2 or outa, leds2 nop nop nop nop andn outa,leds2 nop nop nop nop jmp loop2 leds2 long $50<<16 allleds2 long $FF<<16
my previous response was "duh".
I don't understand why you need to prefix short jumps, setting aside the fact that this is a flat memory model. This will fix all kinds of problems I have been having. I've been having a hell of a time figuring out the assembler on this chip. I think it is because I have been programming assembler since 1976 on a collection of 360, 370,System/3, AS/400, System/34, PC, 808x and most versions, PIC, Arduino, Analog Devices DSP, Motorol DSP, dos masm and I am sure a bunch more. I'm sure there a people around here that can add to this list.
Thanks again.
pasm and spin are quite unusual in some aspects. indirect jmp is one of those things. but not having any stack pasm is different from most assembler-languages. Usually you want a # in front of the jmp target else you will jmp to the content of that adress.
CHIPS way of doing things different is confusing sometimes (lookup min and max for example). On the other hand this is what makes the propeller so great - it is different from other microcontrollers because he is thinking outside of usual used ways.
NEVER assume you understand assembler.there area lot of gotchas hidden there behind well known memnonics. If in doubt ALLWAYS read the manual again. TWICE. Then try to grook it. In most cases you will understand the reasoning behind the decision and will like it.
On the third hand - I still can not wrap my head around MIN and MAX as well as ">=","<=" versus "=<","=>" in Spin they get me EVERY time, again and again.
But think about the beauty of "if_z" and friends. conditional excecuting without speed-penalty. CHIP is brilliant.
Enjoy!
I do wonder why they used the # instead of the more common convention that might have been used with @. So I would jump to a label named "function" (without a # or @) or load the address of that label by using @function into for instance the program counter. The assembler uses the @ correctly on cognew, cognit where you are doing cognew(@function, @stack) or address of function and address of stack.
I am trying to think of a case where you would jump to function without specifying #?
well it is a indirect jmp. For example look at some of the serial objects. They usually use 2 cog-mem-locations as 'state' pointer for rx-thread and tx-thread. each thread is a state-machine saving its 'next-to-execute' adress in its own pointer and jmp to the other ones. This enables some form of multithreading in one cog.
Another example is the jmpret instruction (see Manual) wich allows you to 'call' some subroutine and return to the next instruction, WITHOUT having a stack.
Enjoy!
PASM only has a 512 location memory space, that's why the SRC and DST fields are 9 bits. You can only read and write hub memory, not execute.
btw: can you return from more than one place in a program? I assume not considering the need for the function_ret label.
Here's some trivia. Thinking of jump and return, I don't know how many were arround in the 370 days, but there was a competition to write the simplest program.
It worked out to this:
In 370 assembler, register 14 had the return address of the caller so you were just branching on register 14 to return. The caller in this state was the OS (termed supervisor back then when it was executing) It worked but time went by and someone pointed out the program had a bug. This was an example of a program that had the same number of bugs as lines of compiled instructions since the org was an assembler directive. The return code was supposed to be in register 15 and if not zero, it was conventionally an error. So it was changed to:
Disclaimer: This is a before-morning-coffee answer. If you meant something else please elaborate.
Yes, just do a jump to function_ret. You can dor it with JMP #function_ret, then you have two jumps executed, or more tricky without the # then the CPU does only one jump but picks the address from the ret instruction.
Andy
Edit: As usual, kuroneko was faster ...
